Check this B18c1 setup out!?
Alrite, building this thing for a friend its simple and on a fair budget what you fellas think?
B18c1 block
81.25mm P30 Pistons
Decked 5 thousands
Itr rods
Arp rod bolts
Acl bearings
New oil pump
Mugen 2-Layer headgasket
B18c1 Stock port head
Stock valves
New seals
M22 head packige
Surfaced 7 thousands
Adjustable cam gears
stock fuel rail
Rc 440cc injectors
RM Autolite plugs
Skunk2 intake manifold
Stock tb
aem cold air
DC 4-1 Header (doing the 2.5" collector mod)
Tuning is gona be done on neptune.
We are currently waiting on the block and head to come back from the machine shop and I'll start assembly on it asap!
You guys think this is solid or is there something that might work better than what we currently have?
Thnx,
Adi
B18c1 block
81.25mm P30 Pistons
Decked 5 thousands
Itr rods
Arp rod bolts
Acl bearings
New oil pump
Stock valves
New seals
M22 head packige
stock fuel rail
Rc 440cc injectors
RM Autolite plugs
Stock tb
aem cold air
Thnx,
Adi
loose the header... bore out the TB.. what will this setup be in>?
edit:
its key to make sure you have a very good flowing exhaust system. a good header, mandrel bent piping, and a nice muffler.
edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowridincivic92 »</TD></TR><TR><TD CLASS="quote">loose the header??? yeah do that and blow your head gasket and fry your rings... smart one</TD></TR></TABLE>
what I mean is run a different header. Try reading the rest of the post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowridincivic92 »</TD></TR><TR><TD CLASS="quote">and dont bore the TB it will weaken the walls.. best bet is to buy one to size</TD></TR></TABLE>
His post said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adi Raaa »</TD></TR><TR><TD CLASS="quote">...on a fair budget what you fellas think?
That is why the I suggested to bore out the TB.
are you looking for accel. or top speed? because if you want accel. then get a lightened flywheel but the only downfall is that you deaccel faster but i think that works better if you want a daily driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowridincivic92 »</TD></TR><TR><TD CLASS="quote">you might want to think about a fuel pump as well if you are going to run those big *** injectors</TD></TR></TABLE>
you should be fine, I am running a similar setup and my stock fuel pump is sufficient.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aLLMotorDB8 »</TD></TR><TR><TD CLASS="quote">
you should be fine, I am running a similar setup and my stock fuel pump is sufficient. </TD></TR></TABLE>
reason I say this is because I bought a 255lph fuel pump, currently running 440cc injectors, and I didnt need to install it. If you got other questions PM me if you want. Good Luck!!!
how does your car idle?what do you have under the hood?
