bleeder screw?
I wwent to switch my fans out and took off the upper radiator hose. I now want to re-fill the radiator although I want to make sure there is not air in the lines, radiator. How do I bleed the system on my 97 prelude? Where is the bleeder screw?
the manual i have has no diagram.\ thanks
i'm not sure if the h22 is the same as the h23 but if it is just follow the lower radiator hose to where it meets the engine and there should be the bleeder valves right on top.
Great, thanks for the info, I was under the impression that it was on the thermostat housing attached to the upper hose, but all I found was two mounting screws.
