ctr cams question
Old Aug 28, 2005 | 02:44 PM
8Si8's Avatar
Default ctr cams question
does the ctr intake cam need to be tuned when i put it in or is it fine to just put it in and go? I assume it does not need to be tuned but I don't know for sure and I can't afford to mess something up. thanks
Old Aug 28, 2005 | 04:10 PM
8Si8's Avatar
Default Re: ctr cams question (8Si8)
No input?
Old Aug 28, 2005 | 04:26 PM
ACRProject's Avatar
you don't need to tune them. However, if you do plan to tune your car with the cams than you will make a couple more hp.
Old Aug 28, 2005 | 05:35 PM
SiR Inspired ED7's Avatar
Default Re: ctr cams question (ACRProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACRProject &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to tune them. However, if you do plan to tune your car with the cams than you will make a couple more hp.</TD></TR></TABLE>
Old Aug 28, 2005 | 07:27 PM
sloweredcivic's Avatar
i have heard you don't want to change the factory rev limit with those cams with out changing valve springs but that is arguable
em1_fox
Aug 13, 2009 10:08 AM
EJ8 GSR-T
Feb 20, 2006 09:42 PM
730_Si
Dec 5, 2004 04:53 PM
crooked muffler
May 13, 2003 07:33 PM
