need help : amp wont turn on anymore
after awhile of not having a deck.. my amp was still wired to the car and was on .. now that i have a deck i can finally plug in my subs..i found out that my amp doesnt turn on anymore.. does anyone know whats wrong?..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">after awhile of not having a deck.. my amp was still wired to the car and was on .. now that i have a deck i can finally plug in my subs..i found out that my amp doesnt turn on anymore.. does anyone know whats wrong?.. </TD></TR></TABLE>Have you checked the wiring, is there power on the amps pos. (+) term. and does it have a good ground, and is there power on the amps control lead term. when you turn on the HU?
Was the HUs amp control lead wired to the amp?
94
94
Try this, with a pc of wire jump from the amps power term. the the control term. if the amp turns on, then the amp control lead is not connected at the HU.
94
94
got the amp to turn on but now when i start the car the sub is loud and annoying.. sounds like ground music or watever its called. how do i get rid of it??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">got the amp to turn on but now when i start the car the sub is loud and annoying.. sounds like ground music or watever its called. how do i get rid of it??</TD></TR></TABLE>
Check the ground. Make sure its attached to a clean surface. Take some sand paper to the spot if there paint on it. Also did you run the rca cable on the same side as the power wire? Also did you check your x-over on the amp. Adjust it and see what happens. If that fails check your hu ground.
Also if thats your dc2 in your avatar. Thats a clean ride. Pm me with a better pic I would love to see that thing.
Modified by romoracing at 1:06 AM 8/30/2005
ha its just a pic i grabed i have a 97 integ.. well i have a alpine HU and my remote wire is connected to the wire on the blue hardness wire after this the ground noise comes out whenever i drive.. when i take off the remote wire the amp doesnt power anymore and its normal and has a clean sound.. any help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">ha its just a pic i grabed i have a 97 integ.. well i have a alpine HU and my remote wire is connected to the wire on the blue hardness wire after this the ground noise comes out whenever i drive.. when i take off the remote wire the amp doesnt power anymore and its normal and has a clean sound.. any help?</TD></TR></TABLE>
Alright well this is worth a shot. remove the remote from the hu and from the amp. Then use a wire to connect the power and remote. This works just like the remote. See if the ground noise your talking about still happens.
Also:
did you run the rcas on the other side/middle away from the power wire?
Did you run the power wire on the same side as the battery?
Is you ground from the amp connected to a clean surface?
Also:
iiPancho
Audio / Security / Video
13
Jan 2, 2010 01:29 PM
.Thomas
Jul 26, 2008 03:40 PM
