sub control
Old Jun 5, 2002 | 07:10 PM
MurphDog74's Avatar
Default sub control
is there any receiver accessory that would plug into the preamp on my deck and then the sub audio cables would plug into it, that would give me sub control? My deck doesnt have it and i cant make my sub bump good without makin the speakers bottom out. Thanks
Old Jun 5, 2002 | 08:32 PM
miahmouse's Avatar
Default Re: sub control (MurphDog74)
your post is kinda confusing............
it almost sounds like you wired the sub directly to the deck???
I really hope I'm just reading it wrong and in that case, turn the gain up on the amp
Old Jun 5, 2002 | 09:17 PM
MurphDog74's Avatar
Default Re: sub control (miahmouse)
the amp is wired up to the deck. Even with the gain all the way up it wont bump real hard. If I disconnect the back speakers and send the power to the rear then it bumps good. I want it to do that without havin to disconnect the back speakers.
Old Jun 5, 2002 | 09:23 PM
miahmouse's Avatar
you're not sending enough power to the sub. or, if the sub is a dual voice coil it could possibly be wired wrong (series instead of parallel). If it's wired right then you either need to change the sub out for one that matches the output of the amp, or get a better amp.
iiPancho
Audio / Security / Video
13
Jan 2, 2010 01:29 PM
ChiLS
Feb 21, 2009 10:16 AM
dungsta
Aug 30, 2005 08:59 AM
LudemanDan
Aug 2, 2005 08:16 AM
schwinn
Jun 19, 2002 10:54 PM
