Odd whining noise.
Old Aug 28, 2005 | 01:28 PM
dornon13's Avatar
Default Odd whining noise.
Well i have been hearing this whining noise coming from my engine bay for a couple of days...i figured it was one of the belts too tight but after inspection i'm almost 100% sure its not a belt or one of the accessory pumps yet it is coming from that area of the engine bay. I guess my question is..could the whining be coming from the water pump or maybe the oil pump? I have never had one go out so i dont know if they give off any warning signs or anything before they go out. Thanks.
Old Aug 28, 2005 | 01:34 PM
NJIN BUILDR's Avatar
Default Re: Odd whining noise. (dornon13)
Could be the timing belt tensioner.The oil pump will never make noise and the water pump is usually spraying coolant everywhere when they start making noise.
Glenn
Old Aug 28, 2005 | 02:05 PM
dornon13's Avatar
ill give that a look thanks would you advise just replacing it or are you saying it could be too loose/tight
Old Aug 28, 2005 | 02:26 PM
Probably replace it.Its not big bucks and you need to remove it to check it right.Its good to replace it when you do a timing belt but that doesn't always happen.
Glenn
Old Aug 28, 2005 | 02:45 PM
dornon13's Avatar
Default Re: Odd whining noise. (NJIN BUILDR)
i guess ill go ahead and replace the belt and tensioner since i dont know when it was last replaced...thanks for the help i hope it works
Old Oct 3, 2005 | 09:45 AM
dornon13's Avatar
turned out to be the ac belt tensioner pulley
pityocamptes
Apr 22, 2011 12:40 PM
importfanatic17
Dec 3, 2006 04:39 PM
Ge-money
Sep 6, 2006 02:55 PM
riceburners1
13
Jun 2, 2004 10:57 AM
kevin96GSR
Jan 2, 2004 03:15 PM
