Honda S2000 Honda S2000
AP2 with AP1 cam and ecu?
Old Aug 28, 2005 | 12:23 PM
OMG WTF's Avatar
Default AP2 with AP1 cam and ecu?
Hello,
This is my very first post under this screen name here. I used to post a bit a few years back then i got out of the scene. Just yesterday, i test drove an S2000 for the first time and i fell in love. I will probably be leasing one for business under Hondas special lease special. OK lets get to the point.
Ive seen one or two people mention the use of an AP1 ecu in an AP2 but the post was very vague. I TRIED SEARCHING but no results. Is this a feasible modification and why type of gains would i typically see.
Also i tried seearching for cam specifications and couldnt find anything. What are the differences in cam specifications and are they swappable?
Thanks,
Alex
Old Aug 28, 2005 | 12:28 PM
SuzukaBlueAP2's Avatar
Default Re: AP2 with AP1 cam and ecu? (zclee.com)
if you rev the 2.2L engine on an ECu that's from the 00-03 S2k, you'll blow it up.
If you're leasing, you shouldn't have any plans to modify.
Old Aug 28, 2005 | 12:35 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: AP2 with AP1 cam and ecu? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">If you're leasing, you shouldn't have any plans to modify.</TD></TR></TABLE>
Thats a sad thought. I couldn't handle it.
Old Aug 28, 2005 | 12:38 PM
OMG WTF's Avatar
Yes i realize the AP2s 90+mm stroke may be a bit sketchy revving at 9000rpms but who said i would be doing that?
Yes i will lease, but i am leasing to take advantage of the special lease terms and extensive tax write-offs available. i will probably end up purchasing.
now back to the question.
Old Aug 28, 2005 | 01:13 PM
I'd have to search around some more myself...I can't find any cam specs.
I"ll keep looking.
Old Aug 28, 2005 | 03:15 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com &raquo;</TD></TR><TR><TD CLASS="quote">Yes i realize the AP2s 90+mm stroke may be a bit sketchy revving at 9000rpms but who said i would be doing that?
now back to the question.</TD></TR></TABLE>
that is true, some people have been lucky when they rev past 8000rpms on the ap2 motor, and some havent fared to well either.
Old Aug 28, 2005 | 09:54 PM
OMG WTF's Avatar
So the cam and ecu are interchangable?
Old Aug 29, 2005 | 01:19 PM
bluesaint's Avatar
BTW, AP2 cams provides better low to mid range power, so don't be suprised if you find your mid-range lacking after you swap over the cams.
Old Aug 29, 2005 | 01:28 PM
Mr. Bagel's Avatar
if you are looking for the 9000rpms, the ap1 ecu will be fine. no guarantee though, but yes, it does work.
Old Aug 29, 2005 | 03:12 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: AP2 with AP1 cam and ecu? (Mr. Bagel)
Don't forget to reprogram your key! Also the AP1 ECU is know to lean out certain parts of the powerband, so be careful.
Joey.
May 11, 2007 06:39 AM
1sikhatch
Nov 11, 2006 02:18 PM
chbtek9
Jan 23, 2004 07:22 PM
