how much boost can i go to
Old Aug 28, 2005 | 11:09 AM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default how much boost can i go to
i already searched and nothing came up and FI section nevered answered. i was wondering how much boost can a stock b16 hold.
do you guys think a to4b90 would spool on this engine at all.
thanks in advance
Old Aug 28, 2005 | 11:52 AM
elrandeeto's Avatar
Default Re: how much boost can i go to (turbob16EF)
its not how much boost its how much horsepower i know b18b are good for 300 stock not sure about b16 but to be on the safe side i wouldnt go over 250 260
Old Aug 28, 2005 | 11:57 AM
TH33G4MON3's Avatar
Default Re: how much boost can i go to (elrandeeto)
high compression... always unsure with turbos... low compression
Old Aug 28, 2005 | 12:24 PM
hotimportcrx's Avatar
Default Re: how much boost can i go to (TH33G4MON3)
if you dont wanna repair your car all the time then run like 10psi depending on what size turbo maybe even 8 or 9....i was running 10psi on my b16 daily and had no problems with the block for like 4 months....then i went to 16 daily and cracked the pistons...and i was tuned at 16psi....but then again i knew it woulnt last that long ...compression is to high...just boost and if u blow it throw an ls block in
Old Aug 28, 2005 | 12:37 PM
turbob16ef's Avatar
so 10 psi should be good. my turbo is a super 60 which isnt that big anyways.
thanks alot
Old Aug 28, 2005 | 01:11 PM
Jonny Black's Avatar
yup 10lbs sounds good...been 10lbs for over 2 years..supercharged and turbo charged..and I have the super sixty as well. I make 250 to the wheels..and its been really dependable with my zdyne. I have no worries.
Old Aug 28, 2005 | 01:22 PM
Redline130's Avatar
It's all in the tuning. A good tune will definitely increase your reliability. If the tune is good, high compression and boost can make for a potent combination.
Old Aug 28, 2005 | 02:41 PM
8Si8's Avatar
Set up two different maps, one with low boost (5-7 psi), and one with high boost(10-12 psi) and run the low boost daily and the high boost on the "special" occasions. but it is all in the tuning, the b16 is actually a very strong motor, with a near perfect rod to stroke ratio the pistons will be the first to give out under high boost. has anyone read the last two issues of HCI, they did tests for all of this, if you havn't you need to it is very interesting.
Old Aug 28, 2005 | 03:47 PM
turbob16ef's Avatar
Default Re: how much boost can i go to (8Si8)
i was thinking of doing that but then i thought about it and switching the chips back and forth will get alittle annoying. and after switching them for awhile i will end up just leaving the higher psi chip in there and make my engine more liable to mess up my piston.that is why i am going to just stay at one chip.
Old Aug 28, 2005 | 03:57 PM
8Si8's Avatar
yeah that could get annoying but then again i gut my car every Saturday afternoon just for that night and then put it all back in on Sunday, now it doesn't take too long to do. i see you r up in SC, do you ever ride down here to Sav? is the scene up there any good?
Old Aug 28, 2005 | 05:18 PM
just get your car tuned with uberdata or chrome and get a dual stage boost controller...have one at 6psi and flip the switch to like 12 when u need to (but to run more then 10.47 psi youll need a 3 bar map sensor)
esurds
25
Apr 15, 2010 05:33 AM
ITRBOY1433
Oct 10, 2008 03:54 PM
Dr. D-Series
Jan 21, 2005 07:57 PM
russian_racer
12
May 17, 2003 12:00 AM
