b16a into a crx?
Old Aug 28, 2005 | 10:26 AM
b16a27's Avatar
Default b16a into a crx?
ok i have a 92 DA right now with a b16a in it the plan is swaping into the rex im picking up do u think i can do the swap my self i do know bout cars i changed the tranny already and clutchany pointers and how much it would cost thanxs
Old Aug 28, 2005 | 12:06 PM
RaysBoomBoomLude's Avatar
Default Re: b16a into a crx? (b16a27)
b16a in a CRX requires special Mounts, and Special Shift linkage.
Is your CRX a DX? if so, your going to have to wire for MPFI.
and wire for VTEC.
Old Aug 28, 2005 | 12:13 PM
CRXSI_09's Avatar
Both of which I have for sale.
Old Aug 28, 2005 | 01:26 PM
Mr Synister's Avatar
Default Re: b16a into a crx? (LaFawnduh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh &raquo;</TD></TR><TR><TD CLASS="quote">b16a in a CRX requires special Mounts, and Special Shift linkage. Is your CRX a DX? if so, your going to have to wire for MPFI. and wire for VTEC.</TD></TR></TABLE>
Mans got a point. Also a spare hand would be helpful.
Old Aug 28, 2005 | 04:18 PM
NikoZai's Avatar
Default Re: b16a into a crx? (Mr Synister)
http://www.rywire.com for the wiring.
Old Aug 28, 2005 | 04:30 PM
g-ride-si's Avatar
use the teg axles. if you arent keeping the teg strip everything off of it that you can. If you sell your old parts you can have the swap for free basically, mounts and linkage go to http://www.jdmshit.com and get the hcp mounts and linkage. PPL will tell you to use the hasport but they are way overpriced for making your car vibrate so bad.
Old Aug 28, 2005 | 04:45 PM
Default Re: (g-ride-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">use the teg axles. if you arent keeping the teg strip everything off of it that you can. If you sell your old parts you can have the swap for free basically, mounts and linkage go to http://www.jdmshit.com and get the hcp mounts and linkage. PPL will tell you to use the hasport but they are way overpriced for making your car vibrate so bad. </TD></TR></TABLE>
Ide have to agree somewhat, though I think hasport uses stiffer inserts so the motor doesnt flop around, transfering alot of the vibration to the car. It needs the stiffer inserts cause there is no front mount.
I got my b16 swap with mounts, and shiftlinkage, all hasport, for 1000.
EDIT: also hasport has LIFETIME warrenty. I dunno if HCP has that.
Old Aug 28, 2005 | 07:30 PM
sloweredcivic's Avatar
i love my az race machine full billet with poly bushings and like 200-250 like 100 bucks for there linkage to.
Old Aug 28, 2005 | 09:34 PM
b16a27's Avatar
Default Re: b16a into a crx? (CRXSI_09)
how much for the linkage and mounts
Old Aug 29, 2005 | 06:57 AM
g-ride-si's Avatar
I paid $250 for my mounts and linkage and yes hcp comes with a lifetime warranty also. Ive heard a lot of good things about az race mounts and the avid mounts as well. I used hasport on my old crx and i am a lot more happy with the hcp setup. with the hcps hood clearance with my ls motor was no prob where as wih a b18a in the rex with hasports i had to trim the hood to clear the valve cover.
Old Aug 29, 2005 | 07:29 AM
TH33G4MON3's Avatar
I'm just about finished with mine... just need to do some wiring its fun but frustrating sometimes... good luck
EF_FEVER
Jun 7, 2005 09:22 AM
wid326
Oct 4, 2004 10:36 AM
Neukin
Jul 5, 2003 08:56 PM
Simple
Oct 31, 2002 07:44 PM
jdmed8
Aug 17, 2002 08:43 PM
