projector kits for hid's
ive been looking around, didnt find anyone on ht or internet(as far as i know). could anyone direct me where i can buy projectors to fit my 2000 civic si. i bought the car it already had the hid conversions done to it but i just read the thread about the hid's and im curious where i can get something to make the light more neat.
i mean to get rid of the glare on the headlights, if someone could just tell me what im looking for and where to get it i would appreciate it.
you mean you want to retrofit your headlights with HIDs?
if so, i hope you're ready to put some hrs into getting it done...
check out: http://www.hidplanet.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy »</TD></TR><TR><TD CLASS="quote">you mean you want to retrofit your headlights with HIDs?
check out: http://www.hidplanet.com</TD></TR></TABLE>
He said it has already been done, but now he wants some new headlights for a cleaner line.
-Shane
-Shane
So youve already got an HID kit, but the light glares all over hell-- I know cause I have the same problem. I looked into doing a retrofit, figuring that the projectors wouldnt cost that much and I could just use my aftermarket HID kit and bulbs. Well, after talking to the guys at HIDplanet.com I figured out that I couldnt use my ballasts or bulbs, because the plugs are different and the bulbs dont mount in the projector base. So I gave up because I dont have the money for new ballasts and bulbs, which have to come from a car that came with them stock. Unless your HID's are from another car, you will have to pretty much buy different ballasts and bulbs that mount in the projectors, and then retrofit the projectors in your lights, but it will be worth it!
Question--- Does anyone know what bulbs S2000's use in thier projectors, cause if they are H4's then I dont see why you wouldnt be able to retrofit S2K projectors and use your aftermarket HID kit, cause Civics use H4 bases?? Then you wouldnt have to get new ballasts and bulbs, and you could do a retrofit with your HID's you already have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">He said it has already been done, but now he wants some new headlights for a cleaner line.
-Shane</TD></TR></TABLE>
he never said he had a retrofit done... so i assumed he is using a re-based HID kit.
s2000's HID use d2s bulbs (i'm pretty sure)...
as for using ballasts from a re-based kit to do a retrofit... that's what i did... (look in my sig)
im not sure what or how it was done but they r there now and i would like to clean up the light so people aren't flashing their high beams at me all the time. is there something i can look for on the ballast or something to maybe help you guys answer my question lemme know ill get outside wit my digital.
I'm assuming you have just an H4 HID kit. For the time being, you can reduce glare by aiming your headlights down more.
Then you could go to HIDplanet.com and get a new kit that includes ballasts, bulbs, projectors, and do it yourself, or someone on there would be able to do it for you.
But you won't be able to use your aftermarket HID 'kit' in anything that is OEM, so it's best to do an entire retrofit.
What are those little things called that go under the bulbs-- casper shields, I think? Maybe you dont have those, but they usually come with the HID kits??? That could be the problem, cause I have them in mine and nobody ever flashes me with thier brights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop »</TD></TR><TR><TD CLASS="quote">What are those little things called that go under the bulbs-- casper shields, I think? Maybe you dont have those, but they usually come with the HID kits??? That could be the problem, cause I have them in mine and nobody ever flashes me with thier brights.</TD></TR></TABLE>
$50 for the pair
$50 for the pair
http://www.hidplanet.com/package.html
370+shipping for the kit, expect to pay around 120 if someone does the retrofit for you.
You probably have an eBay kit right now, like these
http://cgi.ebay.com/ebaymotors...QrdZ1
I had one, and they're OK in certain housings, but H4 doesnt do so well.
Do the "HID" you have just put a different bulb in the stock headlight or does your stock headlight have a projector in it?
My guess is you have the H4 HID piece of **** kit. As said, you can get casper shields but it will only do so much.
The problem is the CHROME halogen headlight is reflecting light everywhere.
You can:
Get casper shield, only does so much.
Paint chrome housing, will reduce light output too.
Or most expensive, ditch that setup and get REAL HID. This is expensive and tuff to do in a headlight that didn't have it already. You would need HID projectors, Ballasts, Ignitor and bulbs if the projectors don't have any. Also an upgraded light harness cause your OEM wiring will evenutally fail.
This link has almost every car that has HIDs. You need the parts from one of these vehicles.
http://faqlight.carpassion.info/car-oem-hid.htm
And read up on hidplanet.
You can:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">if you join the forums on hidplanet.com there's several threads on the retrofits into civic headlights </TD></TR></TABLE>
Yeah, do you have any good links you can post here? Im about to do my EK lights and it would be nice to see some tips from someone whose done it already.
http://www.hidplanet.com/forum...rofit
One of those has several people that volunteered to do a retrofit for someone, you could ask them. That person happened to be HT's very own .ken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian22 »</TD></TR><TR><TD CLASS="quote">i got out one of the bulbs, theres like a product number on the bulb here it is. GEHB2 U 12v 60/55w dot</TD></TR></TABLE>
That's not an HID capsule. Do you have any photos?
