ITR Valvetrain
Old Aug 28, 2005 | 08:30 AM
VtecAdvantage's Avatar
Default ITR Valvetrain
Hey guys, i was wondering what the ITR valvetrain consisted of. I was planning on swapping some type-r parts into my B18c1 (pistons and cams) and i was informed that i should upgrade to an ITR valvetrain as well. I found the valve springs, intake and exhaust, but i only found type-r intake valves. Are the exhaust valves the same in the b18c1 and c5?
Thanks
Old Aug 28, 2005 | 09:48 AM
RagingAngel's Avatar
Default Re: ITR Valvetrain (VtecAdvantage)
exhaust valves are the same.
Your lost motions assemblies may be different if your car is older than mid '95....
Otherwise they should have a larger pad and will handle higher lift cams....
Old Aug 28, 2005 | 10:29 AM
Default Re: ITR Valvetrain (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">exhaust valves are the same.
Otherwise they should have a larger pad and will handle higher lift cams....</TD></TR></TABLE>
Thanks,
Yah, im trying to decide between the USDM ITR cams or the J-spec (they say the J-spec has a higher lift and longer duration) from inlinefour.com. I was hoping the ITR valves and springs would work right with either set-up
Old Aug 28, 2005 | 10:33 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecAdvantage &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks,
Yah, im trying to decide between the USDM ITR cams or the J-spec (they say the J-spec has a higher lift and longer duration) from inlinefour.com. I was hoping the ITR valves and springs would work right with either set-up</TD></TR></TABLE>
The JDM intake cam had minimally more lift and longer duration but is the same as the USDM R cam from 00-01. Save your money on the JDM stuff and just find some used USDM ones, or even just the USDM R intake and stock GSR exhaust.
Old Aug 28, 2005 | 10:46 AM
Default Re: ITR Valvetrain (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">The JDM intake cam had minimally more lift and longer duration but is the same as the USDM R cam from 00-01. Save your money on the JDM stuff and just find some used USDM ones, or even just the USDM R intake and stock GSR exhaust.</TD></TR></TABLE>
Well ****.. i have ITBs comming soon. I would have an upgraded intake cam, valves, and springs but stock for the exhaust - would that be alright? Or is the exhaust perfectly fine?
xeejay
Feb 16, 2016 07:40 PM
ilovemyh22
Feb 18, 2009 03:08 PM
TurBoTeG
Mar 10, 2007 08:48 AM
kill y-tee
Jan 19, 2007 07:08 PM
EG6-B18C6
Apr 30, 2005 01:45 AM
