1993 r1 FD RX 7 in NC
Guest
Posts: n/a
its 1993 r1 version, less than 55k on the chassis, less than 2000 miles on the new reman motor. new clutch and newer turbos were installed when the motor was replaced. comes with full exhaust on it (dp and mp are hks, and apexi gt spec catback). greddy intakes, aluminum ast, manual boost controller (not installed), defi boost gauge, greddy turbo timer, and nippon aftermarket fuel pump. has full non-sequential turbo setup, and no rats nest. all it needs is an ecu of some sorts and itll be very reliable. right now the car is only running at 7lbs of boost, because a restrictive pill is in the wg line.
because it is a 12 year old car, there is bit of dings and chips. the driver side seat has a little tear, and the panels are scuffed up. i will get pictures of these sometime soon. i would like to get $12,500. thank you. also, the car does not come with the volks, it has stock wheels on it now, but the newer reinforced ones.
i bought this car from allrotor93 on rx7club.com and his mechanic has done all the work. the motor still has a warranty until may 2006.
i am located in wilmington, nc also. email is SOHChatchback@hotmail.com
thank you for your time.
Modified by .DOHChi at 3:36 PM 10/25/2005
rjc898
May 16, 2005 09:03 AM
