b18c into 91 dx wont start help searched!!!!
Old Aug 27, 2005 | 06:03 PM
lilbc1390's Avatar
Default b18c into 91 dx wont start help searched!!!!
I have recently finished my b18c swap intio my dx. It wont start. I am getting gas but no spark wat so ever. I am using a sohc p28 i dont know if that will make a difference. If some one could have some things for me to chekc please leave them. HELP!!!!!
Old Aug 27, 2005 | 06:18 PM
Rywire's Avatar
Default Re: b18c into 91 dx wont start help searched!!!! (lilbc1390)
break out the mulitmeter, and check the wires to the ecu, then look into a bad dizzy
Old Aug 27, 2005 | 06:21 PM
EFvtec Yo!'s Avatar
CHeck all the wiring at the dizzy and the ones going to the ecu since you had to do the dpfi-mpfi swap. Make sure all your grounds are being used. The thermostat housing ground is a common one to overlook.
Old Aug 28, 2005 | 07:04 PM
lilbc1390's Avatar
Default Re: (EFvtec Yo!)
So the only ground i have hooked up is the battery ground wat other ground should i hook up and explain where please. Thanx.
Old Aug 29, 2005 | 09:21 AM
EFvtec Yo!'s Avatar
Default Re: (lilbc1390)
in the engine bay you should have a couple of grounds going to the chassis. You should have one on the valve cover, tranny, and thermostat housing. I'm not sure about the valve cover or tranny, but i am sure that it wont crank if you dont use the thermostat ground.
Old Aug 29, 2005 | 09:41 AM
teewhy55's Avatar
did he say hes using an sohc p28 on a b18c1, that just sounds wrong...
Old Aug 29, 2005 | 10:11 AM
lilbc1390's Avatar
So now that i have the grounds all figured out is a problem to use a 94 sohc vtec delsol ecu (p28) or will it still start and then ill have to get it chipped. basically im wondering if it will start with this sohc p28 ecu?
Old Aug 29, 2005 | 10:29 AM
DUFFM4N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">break out the mulitmeter, and check the wires to the ecu, then look into a bad dizzy</TD></TR></TABLE>
it doesnt make a difference all that much that ur running a P28 cuz all its gonna do is allow u to hit vtec...but u should get the right ecu soon so that ur getting the right amount of fuel
Old Aug 29, 2005 | 10:40 AM
lilbc1390's Avatar
Default Re: (DUFFM4N)
Alright cool thanx im going to try and hook up all those grounds and see if it will fire and then later wat kind of ecu should i get?
Old Aug 29, 2005 | 11:52 AM
EFvtec Yo!'s Avatar
you mostly likely will want to use a p72(gsr ecu) or get the p28 chipped
Old Aug 29, 2005 | 11:57 AM
DUFFM4N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFvtec Yo! &raquo;</TD></TR><TR><TD CLASS="quote">you mostly likely will want to use a p72(gsr ecu) or get the p28 chipped</TD></TR></TABLE>
get ur p28 chipped
Old Aug 29, 2005 | 02:37 PM
lilbc1390's Avatar
alright thanx ill post wen its all done it will end up being a built gsr t3/t4 turbo. thanx for the help!!!
Old Aug 30, 2005 | 05:54 PM
lilbc1390's Avatar
So now that i hooked up all the grounds i got spark but it still wont fire up. I am very confused now. I did the dpfi-mpfi swap but am not feeling i did something wrong please give me some info on wat to check!! thanx
Old Aug 30, 2005 | 06:37 PM
b18cEF9's Avatar
SEARCH, dont expect people to give you all the answers. top right hand corner click the button that says search, not that my rant is over
you have fuel, you have spark, what about your timing? or compression
phirewire
Oct 23, 2011 10:55 AM
94RedEGCoupe
Apr 23, 2004 06:58 AM
bagged lude
Mar 31, 2004 07:14 PM
I8ayellowcrayon
Jan 6, 2004 06:29 AM
SpoolinEK
10
Oct 27, 2003 04:27 AM
