can crank angle set oof my timing
Old Aug 27, 2005 | 05:00 PM
88crxdxfastwhip's Avatar
Default can crank angle set off my timing
ok i have posted this up alot but here it goes agian i broke my water pump in my crx a few months back got it fixed abouta week later dude said after he fixed it he couldent figure out why it wouldent stay running but now i get it back and it runs like **** after it falls under s1200 rpms cel cuts on and car bogs down to a die sounds like the intake farts and just dies i have to set the idle higher but it sounds bad when you runnin it a 2000rpms every where you go plus it sounds like my exhuast is crackling is that normal it makes like little pop and crackle sounds i dont remember it doing that before my main relay is going out but i dont think thats the problem my ecu is 7 and 15 that crank angle and fuel injectors but i dont think my fuel injectors are the ones doing this the mechanic said he is positive its on time but then what the hell is it where is the crank angle sensor how do i replace it or fix it?????? sorry for bad grammer..
Turyem2
Honda Civic (2001 - 2005)
Jan 6, 2018 03:48 PM
Dangousity
Feb 10, 2010 03:58 AM
Shad0wcat
Oct 8, 2006 10:57 AM
88crxdxfastwhip
Aug 31, 2005 11:24 AM
93civdx
Jun 21, 2003 09:17 AM
