Engine motor mount bushings???
Old Feb 25, 2002 | 08:26 AM
Integra_B18B's Avatar
New User
Default Engine motor mount bushings???
I'm thinking about getting engine motor mounts for my 98 Integra. Will they help alot?
Also, I know about the Energy Suspension ones. But I hear at idle the whole car will shake like mad and stuff. Is there a bushing out there on the market that does the job but doesn't make the car shake like mad????
Thanx
Old Feb 25, 2002 | 09:41 AM
BlowOff's Avatar
New User
Default Re: Engine motor mount bushings??? (Integra_B18B)
Some people say the new mounts help reduce wheel hop. I don't think my energy suspension bushings did anything but make the whole car vibrate like a biotch!
Old Feb 25, 2002 | 11:27 AM
Bert's Avatar
Default Re: Engine motor mount bushings??? (BlowOff)
Yeah... the inserts I have didn;t do anything for wheel hop... made the car vibrate a lot at idle. I'm thinking about taking out the inserts from one or more mounts to see if that helps the vibration. The z10 radius rods kit is the only thing that's helped wheel hop for me.
Old Feb 25, 2002 | 01:33 PM
Fez's Avatar
Fez
Default Re: Engine motor mount bushings??? (Bert)
Where can I get a "z10 radius rods kit" and how much does it cost?
Old Feb 25, 2002 | 06:05 PM
ithrowpoop's Avatar
Default Re: Engine motor mount bushings??? (GSRjunky)
I put the energy suspension kit in my 2000 gs-r and the wheel hop was reduced to almost nothing. The z-10 radius rod is good but I think it is more for track applications than street.
Old Feb 25, 2002 | 06:20 PM
Bert's Avatar
Default Re: Engine motor mount bushings??? (BY2KGSR)
I had less of a wheel hop problem with my 205/50/15 Dunlop sp4000's... now I have Pirelli P7000 215/45/16's and it seems like the added traction made the wheel hop worse. The z10 kit helped wheel hop a lot... it takes some work to induce it now. I think one more turn will completely eliminate all hop. Fitment was pretty tight as it just barely (like 1/8") clears my moroso oil pan. There should be plenty of space with the stock pan, though. The kit also seems to tighten up the steering a bit and reduce squat during acceleration.
GSRjunky, the z10 site is http://www.z10eng.com/index2.htm
Old Feb 26, 2002 | 06:54 AM
New User
How much is the Z10 kit??
Also, anyone know if there is an aftermarket engine mount bushing that doesn't make your car shake like mad????
Thanks
Old Feb 26, 2002 | 08:22 AM
Bert's Avatar
Looks like 330 + shipping from the group buy https://honda-tech.com/zerothread?id=73666. Although they did ship my kit to my billing instead of shipping address when I ordered and cost me 5 hours of driving
I think all poly engine mount inserts make the car vibrate... nature of the beast. The stock mounts are mushy to absorb the vibration... stiffer ones transmit it to the body more.
Old Feb 26, 2002 | 08:23 AM
shamoo's Avatar
Will you make something up for me please?
Thanks
Check http://www.z10eng.com for the prices. Also there is a groupbuy here on Honda-tech as well aas http://www.groupbuycenter.com . It's like a little over $300 if I'm not mistaken.
Most if not all aftermarket motor mounts will make your car shake more. That's what they do....they are stiffer than the stock ones, hence your car will transmit more vibration from the motor. If you get a soft mount, it defeats the purpose of getting one, unless you're just replacing a worn out stock one.
Old Feb 26, 2002 | 08:33 AM
Bert's Avatar
Default Re: Engine motor mount bushings??? (shamoo)
Beat you by a minute
Eerily similar post, though.
Old Feb 26, 2002 | 09:04 AM
jamal-188's Avatar
I think stiffer motor mounts are to reduce engine flex so it doesn't lean back as much when you shift/accelerate which in tern increases traction and reduced wheel hop.
Old Feb 26, 2002 | 09:13 AM
Bert's Avatar
Default Re: Engine motor mount bushings??? (jamal-188)
yeah.... that's why I got them. Once they were installed I still had crazy wheel hop. The only difference I noticed was the vibration and maybe slightly harder launches.
2DoorBandit
Suspension & Brakes
May 28, 2006 02:44 PM
elitesi8
Oct 9, 2005 06:42 AM
AznBlueBoy
Aug 11, 2005 11:09 PM
Hybrid96EK
Feb 9, 2005 11:16 PM
JICsube
Jul 21, 2002 06:54 PM
