181whp and still slow?
Old Aug 27, 2005 | 03:34 PM
Easyslider01's Avatar
Default 181whp and still slow?
dynoed at 181whp 127tq in a vx hatch
buddy club spec 3+ cams, valvetrain
skunk 2 IM, 4-1 header
Hondata s100
JDM GSR
went to the track, around 73 degrees out
2.28 60ft
14.299 @98mph
I was shifting at 8700, so what gives, i can't figure out why i'm not breaking 13's, I mean I ran a 14.2 when all i had was intake and exhaust!
[IMG]dynoed at 181whp 127tq in a vx hatch
Hondata s100
JDM GSR
Old Aug 27, 2005 | 06:09 PM
young noob's Avatar
Default Re: 181whp and still slow? (Easyslider01)
maybe its retarted.............. the timing that is
Old Aug 27, 2005 | 08:39 PM
rhd type r's Avatar
several things could be causing you trouble. first of all if you cannot cut a
2.00 60 ft. you have traction problems. also if you look at your dyno sheet, you should notice that you start to loose power after about 8200 rpm. if i were you i would set my shift light between 7800 and 8200 rpms. its not worth pushing the head that far, especially sence you are loosing power.
Old Aug 28, 2005 | 07:24 AM
G2 Speed's Avatar
torque... you need torque
Old Aug 28, 2005 | 12:53 PM
rhd type r's Avatar
torque will help, but more torque will also give him more wheel spin. he has enough hp to run high 13's
Old Aug 28, 2005 | 12:59 PM
ThatsMyEG's Avatar
Default Re: 181whp and still slow? (rhd type r)
my friend ran stage 2 cams in a crx with a gsr, dyno 170hp and he ran a 13.3 i think you should be in the mid 13s on slicks, but id shift around 8200.
egsir2
15
Oct 5, 2006 07:33 AM
Easyslider01
Aug 28, 2005 12:05 PM
red civic standard
Apr 24, 2005 01:17 PM
xEGxB18Cx
Aug 15, 2003 05:41 AM
HondaGSR
31
Dec 4, 2002 07:49 PM
