Knock sensor cause car to not start?
Old Aug 27, 2005 | 02:55 PM
duggy's Avatar
Default Knock sensor cause car to not start?
Okay here's the deal.
I have a 95 GSR motor in a 92 Hatchback. I haven't wired up vtec or knock because I am going to get the ECU chipped anyways and haven't wired up vtec because I want to break the motor in so wiring up vtec is pointless for now anyways.
Anyways, will the knock sensor put the car in limp mode, or cause it not to start?
Old Aug 27, 2005 | 02:57 PM
EK k kay's Avatar
Default Re: Knock sensor cause car to not start? (duggy)
No it will not make the car not start.
Old Aug 27, 2005 | 03:17 PM
duggy's Avatar
lol
So it won't affect it any right?
Old Aug 27, 2005 | 03:21 PM
1.8EG-T's Avatar
Default Re: (duggy)
You will get a check engine light...just hook it up, even for the break in. Just don't rev the **** out of it or keep it at any certain RPM for great lengths of time.
Old Aug 27, 2005 | 03:23 PM
duggy's Avatar
Isn't it easier to get the ECU chipped than to not hook it up? Sure is.
Any other ideas? I got the motor from HMO so it should be good. I'm cranking it and it won't turn over. I figure it's been sittin for a while and just needs to be cranked for a while. I changed the oil and all that.
Old Aug 27, 2005 | 03:24 PM
1.8EG-T's Avatar
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it easier to get the ECU chipped than to not hook it up? Sure is.
Any other ideas? I got the motor from HMO so it should be good. I'm cranking it and it won't turn over. I figure it's been sittin for a while and just needs to be cranked for a while. I changed the oil and all that.</TD></TR></TABLE>
I guess...good luck with your problem, every motor that I have put in started on the first/second try...sounds like you have a problem...sure does...
Old Aug 27, 2005 | 03:25 PM
duggy's Avatar
I spoke to a few friends and they have all had the same problems and just crank it for a while.
I hope this is true.
Old Aug 27, 2005 | 04:13 PM
duggy's Avatar
bump
Old Aug 27, 2005 | 05:24 PM
1.8EG-T's Avatar
Default Re: (duggy)
Have you not cranked it enough yet?
Old Aug 27, 2005 | 06:59 PM
duggy's Avatar
I have actually cranked it alot
Old Aug 27, 2005 | 07:01 PM
Kyles ej1's Avatar
Default Re: (duggy)
was the motor rebuilt or something cuz theres no need to break it in if you bought it used
NA JDM GSR
Dec 1, 2006 08:52 AM
ek9jdm
Jul 22, 2006 11:36 AM
Kangolbrand
Mar 12, 2006 10:43 AM
0554
Jun 10, 2003 05:41 PM
