Suspension & Brakes Theory, alignment, spring rates....
Radius rod noise with z10 crossmember
Old Aug 27, 2005 | 01:14 PM
ham's Avatar
ham
Default Radius rod noise with z10 crossmember
I have a z10 crossmember on my crx and when i hit small bumps I hear and feel a clunking like a have bad ball joints. When I kick the wheel, it feels like the radius rods are moving. Do those heim joints ever go bad? I loosened it up and moved the knuckle forward and it made a difference having some tension on there. Anybody know what i can do?
I have H&R race springs, blues, new HF rack, somewhat new crossmember, ST sway bars, full poly kit.
Thanks
Old Aug 29, 2005 | 02:09 AM
Full-Race Geoff's Avatar
Default Re: Radius rod noise with z10 crossmember (ham)
heims do go bad, and the z10 heims are pretty cheap, i recommend upgrading them to a higher quality heim
Old Aug 29, 2005 | 05:29 AM
.RJ's Avatar
.RJ
Default Re: Radius rod noise with z10 crossmember (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">heims do go bad</TD></TR></TABLE>
They sure as **** do. They are a wear item on a race car.
Old Aug 29, 2005 | 06:04 AM
ham's Avatar
ham
Default Re: Radius rod noise with z10 crossmember (.RJ)
where can i get some better ones???
Old Aug 29, 2005 | 06:05 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">where can i get some better ones???</TD></TR></TABLE>
http://www.aurorabearing.com/
Old Aug 29, 2005 | 06:19 AM
Dragline's Avatar
You should get some teflon lined ones there better for the street and also use rod end seals to seal out dirt and other things from getting into the joints and they should last alot longer.
Old Aug 29, 2005 | 06:36 AM
.RJ's Avatar
.RJ
Default Re: Radius rod noise with z10 crossmember (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">You should get some teflon lined ones there better for the street </TD></TR></TABLE>
Dont do that. The teflon will come off the surface and seize the bearing.
Dust seals are good, however.
Old Aug 29, 2005 | 06:43 AM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Dust seals are good, however.</TD></TR></TABLE>
I have never had A problem with the teflon coming off. What brand are you using?
Old Aug 29, 2005 | 06:50 AM
.RJ's Avatar
.RJ
I have never had A problem with the teflon coming off. What brand are you using?</TD></TR></TABLE>
How many street/track miles on them?
Old Aug 29, 2005 | 07:20 AM
Dragline's Avatar
How many street/track miles on them?</TD></TR></TABLE>
Not sure of miles but I have built A couple sets of traction bars and have always used teflon, thats why I ask what brand you use because I use QA1 XM-XF series and the way there designed is that the liner is locked into the body of the rod end, If I can find batterys for my camera I will take pics and show you there design.
Here's the pic sorry but my camera sucks,but you can see how the liner comes out to the edge and the body is notched to hold it in place. It says on there site that it is designed not to pound out like other brands.
Click it to enlarge
Modified by dragline at 11:47 AM 8/29/2005
Old Aug 29, 2005 | 08:52 AM
ham's Avatar
ham
I dont have any seals on mine.
Send some more links!!
Old Aug 29, 2005 | 01:41 PM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">I dont have any seals on mine.
Send some more links!!</TD></TR></TABLE>
Here's the seals
http://www.bakerprecision.com/rodacc.htm
Old Aug 29, 2005 | 02:17 PM
ham's Avatar
ham
Here's the seals
http://www.bakerprecision.com/rodacc.htm</TD></TR></TABLE>
thanks! do you know the size off the top of your head?
Old Aug 29, 2005 | 02:38 PM
Dragline's Avatar
thanks! do you know the size off the top of your head?</TD></TR></TABLE>
I don't know what size bolts Z10 uses just measure the bolts you have it's probably 1/2" or 5/8"
Old Sep 4, 2005 | 02:45 PM
ham's Avatar
ham
5/8!!!!!!
1badf20
Honda S2000
Sep 2, 2007 12:30 PM
ef 4 door
Suspension & Brakes
Dec 11, 2006 02:20 PM
DFW
Suspension & Brakes
Sep 16, 2006 11:32 AM
burplelude
Jul 10, 2006 12:11 AM
Deo
13
Mar 1, 2006 06:39 AM
