Tranny gurus what is this bearing called
edit: ok found out its called the Differential bearing and there are 2 of them. My question is at the bottom of this thread
(edid)crap I forgot to add the picture LOL
Modified by crexer at 5:45 PM 8/27/2005
Modified by crexer at 7:54 PM 8/28/2005
on http://www.hondaautomotiveparts.com they just call it a bearing so thats not really helpful. When i removed the tranny casing the very top 2 bearings that you first see when the case is removed, they spin freely and make no sound whenever spun but they one in that picture makes sorta a metal to metal sound when spun. I guess that means its bad or is it supposed to sound like that?
Ok well the top differential bearing (pictured) from a dx tranny is not the same as the si tranny. Whenever this bearing is spun by hand it sounds like a skateboard wheel whereas the other bearings are farily quite. I have replaced the input shaft bearing and dont have time to wait to order a differential bearing (2) acutally. Does anyone know if the diff. bearing is supposed to have some sound when spun by hand or is that an indication it is bad. I hate to replaced both differential bearings at $30 a peice and it not even need to be. My symptoms are that identical to what everyone is saying input shaft bearing. I need some advice here.
the only bearing i have replaced is NUMBER #15 will this fix my problem as of right now or no?
Modified by crexer at 10:31 PM 8/28/2005
parahelium
Transmission & Drivetrain
Jun 8, 2017 10:46 AM
HondaEJ7
Dec 6, 2006 06:11 PM
crexer
Aug 28, 2005 06:39 PM
