Cuts Out at High RPM- ? Out of Ideas....
Old Aug 27, 2005 | 12:00 PM
asubennett's Avatar
Default Cuts Out at High RPM- ? Out of Ideas....
Motor is in my sig. The problem is new.
Compression test is 295 across the board. I have checked all grounds. I have replaced plug wires. I have changed spark plugs. I have checked all wiring on the harness.
Car pulls very strong right to 8800 rpm and then it just cuts out just as if it was hitting a rev limiter which my ECU does not have.
AFR's at WOT right before it cuts out is 12.7:1
Could my ECU be faulty. Any other ideas? Bad cap and rotor? If someone can point me in the right direction so I don't spend my whole weekend trouble shooting I would be most appreciative.
Old Aug 27, 2005 | 04:30 PM
asubennett's Avatar
Default Re: Cuts Out at High RPM- ? Out of Ideas.... (asubennett)
bump
Old Aug 28, 2005 | 11:06 PM
Jago's Avatar
a coil maybe
Old Aug 29, 2005 | 09:38 AM
lowridincivic92's Avatar
Default Re: Cuts Out at High RPM- ? Out of Ideas.... (Jago)
what kinda of motor do you have i have a 92 vx, and it has the vtec-e and it wont go to 8800
Old Aug 29, 2005 | 09:46 AM
asubennett's Avatar
Default Re: Cuts Out at High RPM- ? Out of Ideas.... (lowridincivic92)
Motor is in my sig. What is VTEC-E?
Old Aug 29, 2005 | 09:47 AM
there is no motor in your sig.
MasterFunk
Aug 28, 2008 06:38 PM
Slow_4_Now
Aug 13, 2006 08:03 PM
asubennett
Aug 27, 2005 10:15 PM
EGinNY
Mar 6, 2005 07:42 PM
