boost on a stroker motor
Alright, I’ve been doing some research, but I keep getting mixed results. Everyone says that it will be fast, but know one can agree on how dependable it will be. Most people are saying that is will hold up for six or eight months, and then the crank will break. What do yall think?
the motor is a b18a golden eagle block 85mm bore with an eagle 92mm stroker crank kit. i havent decided what pistons to go with, it just depends on if i go nitrous or turbo.
Modified by rhd type r at 9:42 AM 8/27/2005
If its not tuned to the edge of destruction , it should last just fine.It would be a little safer at 83mm or 84mm for boost, but it still can be done at 85mm.The stroke wouldn't bother me at all.There is no reason the crank should break.
Glenn
Glenn
