dumb ? bout engine swap
im lookin at a lsd b16a2 gen2. is that obd1 or obd2??? and if its obd2 do you have to convert it to 1 for the greddy turo kit emanage to work on it??? thanks
good luck finding a LSD b16a2 cause Honda never made a b16a2 with a LSD tranny. BTW thats a OBDII motor. And im pretty sure that plugs match right up in the engine bay
You can get a SIRII swap with a LSD. You can put any engine year into a car that you want. They make ecu conversion harness's for that reason.
B16A Gen2 OBD1 Motor Swap (LSD)
Product condition : Used
ONLY ONE MORE IN STOCK!!
B16A Gen2 OBD1 Motor Swap (LSD), 1595cc, DOHC VTEC, 170 bhp @ 7600 rpm, Redline: 8200. Requires Profes...
from passwordjdm.com unless theres a couple typo's in there...otherwise is there any other explanations
is the si-R have a b16a2 in it to???
sound like its a sir(b16a)(lsd). some of the sir's came w/lsd trannies. the b16a2 did not come w/ lsd.
the horsepower kinda gives it away. 170hp.
the b16a2 came w/ 160hp.
courtmakemehorny
Apr 22, 2005 03:13 PM
