which engine in my del sol?
im looking at replacing my old d16z6 engine with a b16a2 there are rather a few choices to pick from what are the the best im looking between the b16a2 with lsd and the obd2 or the obd1 or an engine without the lsd? i dont know what to pick its going to be a complete swap with what i do. Please help. i'll be buying a turbo soon after so any help on which would be best for it all??
Re: which engine in my del sol? (courtmakemehorny)
1st gen B16's aren't nearly as fast as the newer ones but sell for a cheaper price. Keep that in mind when you order. And LSD gets from me. It's also a lot cheaper to get the swap with LSD than it is to buy and install later. My $.02.
Re: which engine in my del sol? (ReD . EK)
The B16A3 or B16A2 with the S21 tranny (came with US B16A2/3) shouldn't be hard to fit. No US market S21 transmission came with an LSD from the factory.
A3 is ODB1, A2 is ODB2. Which to use depends on what age your car is. If your car is 96+, and will be driven on public roads, legally you must get a ODB-2 engine. Otherwise you can use either one.
My problem with the S21 is the top gear, it turns around 3K RPM when doing 55.
sleepyhamsterlx
12-18-2003 01:56 PM
