Turbo h22 or not?
You guys think i should turbo my car or not? I mean i'm building a turbo kit right now but not sure of turbo'in my car. scared of the ringlands... If i do go turbo i will get it tuned first thing when turbo is installed... but i don't know. What do you guys think? I have a stock JDM H22A motor in a 93 Prelude .. This is the setup im going for.
Turbonetics T3T4 .48 .57, DSM 450cc, Uberdata P28, Greddy Type S BOV and Relief valve, tial wastegate 7 or 8lb spring, walbro 255 fp. jrc 8 in fmic, rev hard manifold
Modified by 93JDMH22A at 11:15 AM 8/27/2005
aparantly hes in the process of the turbo kit. get the rest of the stuff, turbo that ****, its awesome. just plan on building the bottom end after a while and do not run more than 8 psi.
I say go for it ... turbo that bad boy ... just don't go over 7 or 8 psi if you don't plan on building the block at all. Or you'll do what my did and crack your block. Good luck though
Dont worry about how many pounds too run, just keep it under the 275whp mark. It will last a little longer there. Before I built mine, I had around 320whp and beat the **** out of it daily. I was using AEM EMS. It blew in 7 months. It held up longer than I thought it would.
Go ahead and turbo it man. Seriously, I've been turbo'd on my lude for quite some time and the rush you get from the tq is more than any N/A lude can dish out IMO. Also, I'm a ricer so I love my blow off valve! haha never get sick of it. I'm pushing 7 psi on my deltagate and it's fine, I'm still on a base map (in korea now so the car's parked) but my car was plenty quck! Go turbo man, you won't regret it, if you need any more advice feel free to pm me .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super accord »</TD></TR><TR><TD CLASS="quote">Hey check under ebay. look under h22 you can find some cheap parts. they also have a couple of already built h22 turbo engines. well i hope this helps.</TD></TR></TABLE>
REALLY BAD IDEA: do not listen to this guy. Those cheap parts are horrible. the manifolds are mostly ss autochrome or a sub-let of them. THey have huge tendencies to crack like crazy. Do not cheap out on your motor man, you will regret it because it will cost you more in the long run. Cheap and turbo do not match.
i dont use cheap parts i know better.
Read my first post thats my setup im going for. I already have most of the parts. now its time for the oil line kit
booja
Aug 3, 2005 09:17 PM
