high idle problems with b16 WHBAT could it be
Old Aug 27, 2005 | 12:45 AM
91_civicsi's Avatar
Default high idle problems with b16 WHBAT could it be
okay so when i start my car the engine idles around 3000 rpms or so, i understan dits normal to hav ea coldstart,, but this is a little bit too high i think :S
now about a week ago i had a problem where it would stall out randomly at lights/stop signs when i put in the clutch, so my buddy said it could be a dirty throttle bodyk, so i used brake cleaner and cleaned out the tb, and it worked great up until yesterday, at operating temp the car idle around the 1500-1700 range , whic his way too high, so i used the idle screw on the tb, i turned it down, it idled fine at 900 rpm for a bit, now when i drive it with the screw turned down it stalls every single time i put the clutch it, stalls right out
so i had to put the idle screw back upk, and its idling at 1500-1700 normally agian :S
what is wrong...., searched, didn't find anything on this issue
Old Aug 27, 2005 | 02:22 AM
SLOASSREX's Avatar
Default Re: high idle problems with b16 WHBAT could it be (91_civicsi)
sounds like your iacv is takin a crap
Old Aug 27, 2005 | 04:50 AM
mar778c's Avatar
Community Builder
Community Influencer
FITV, TPS, or PCV valve. Either or those will cause your idle to be high. I would replace the PVC valve first, then check the voltage on your TPS. Those are easy and cheap to do. The FITV can be fixed. There's a thread on the subject floating here.
Old Aug 27, 2005 | 06:55 AM
89s1's Avatar
Default Re: high idle problems with b16 WHBAT could it be (mar778c)
adam, I would check for vacuum leaks before doing anything that costs money
but i agree that something in the intake tract is crappin out.
Old Aug 28, 2005 | 12:51 AM
91_civicsi's Avatar
**** i dunno what it is, but its really pissing me off with gas being so expensive and the idle being so high
i hope i can figure this **** out soon,
Old Aug 28, 2005 | 12:55 AM
sam385's Avatar
Default Re: (91_civicsi)
iacv leaky vacuum hose.
check first
Civicfanatic_09
17
Jul 16, 2012 12:04 AM
mrx
13
Apr 4, 2009 08:31 AM
90_Si
26
Jan 22, 2008 06:38 PM
PWRDbyHseries
Oct 18, 2006 05:44 PM
chirp2hrd
Oct 13, 2002 01:36 AM
