Clutch Question on 93 Si ??
Old Aug 26, 2005 | 08:35 PM
Polish_dude's Avatar
Default Clutch Question on 93 Si ??
Problem started this morning, i gunned it from first to 2nd, and then i wanted to gradually put it into third and it barely got into gear, so i pulled over,
tried to put it into first again, no dice, turned off car, went into first fine, turned car back on, started shuddering when i took off normally, shift into 2nd was hard also, had 2 force it, clutch is one month old, and doesnt slip even after this problem started,
Also, when i start car in 1st it starts moving, with clutch in?!?
friend had same problem , started happening month after his clutch was done, turned to be clutch cylinder? PLEASE HELP<
Old Aug 27, 2005 | 11:14 AM
LudemanDan's Avatar
Default Re: Clutch Question on 93 Si ?? (Polish_dude)
Your clutch isn't disengaging all the way.
I wish I could help you more than that, but I just haven't torn into clutches yet.
Dan
Old Aug 30, 2005 | 04:28 AM
dognutz's Avatar
Default Re: Clutch Question on 93 Si ?? (LudemanDan)
I would start by bleeding the system. If this doesn't help it may be your slave cylinder. If you have not replaced it it maybe a good place to start. Also replace you clutch master cylinder at the same time. This gives you all new clutch/hydraulic components. So you can feel confident in you clutch systems.
Duck55
Mar 2, 2010 05:49 PM
vinceg143
Aug 20, 2008 03:24 PM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
Polish_dude
Aug 25, 2005 02:04 AM
esoterEK..
Oct 5, 2003 10:26 AM
