Suspension & Brakes Theory, alignment, spring rates....
all handling **searched**
Old Aug 26, 2005 | 07:53 PM
SomeDude56's Avatar
Default all handling **searched**
im more of a handling guy so i was wondering what the best setup would be for a 88 crx for just purely handling? and quit possibly less than a thousand dollars... and besides konis and gc's plz...... but i wouldnt mind knowing how much better the konis and gc's in the field of handling?
thanks in advance
Old Aug 26, 2005 | 08:14 PM
chrisw85's Avatar
Well of course get yourself a Koni/GC setup with some pretty decent rates. This is perhaps the best combo out there for $790 with custom rates. Think about the SPSS race-valved shocks also.
Something i can think of, bushings; solid (delrin) spherical, or just new fresh oem rubber ones. 88 crx they are prob shot. Could go poly, but they do have downsides.
Then look at sway bars, esp a bigger rear bar.
Alignment can make a huge difference in how you handle.
As will tires and tire compounds.
But for your target budget of $1000, the Koni/GC, the GC tophats, and a rear sway bar and tires. You will be over $1000, but its money well spent.
Old Aug 26, 2005 | 09:16 PM
PIC Performance's Avatar
Default Re: (chrisw85)
Ah I'm glad someone mentioned Delrin. I was looking into Delrin (and Delrin AF), and found out that they have some machining issues. Particularly that they tend to get porous (?) towards the center when you have large diameter rods of it, they deform under the heat of machining, making things imprecise... is this true? If you need to insert the bushing sleeves, wouldn't this cause them to fit poorly and slip out over time?
Old Aug 27, 2005 | 12:16 AM
Tyson's Avatar
Default Re: all handling **searched** (SomeDude56)
my 88 CRX si on stock springs and upgraded sway bars front and back with illuminas all around is the best handling car ive setup, for the street.
if i wanted to go a bit lower, id put my eibach pro kits on, but i like it the way it is now.
Old Aug 27, 2005 | 11:03 AM
chinese acrobat's Avatar
Top handling go with H&R
DONT GO TEIN
WAY OVERATED
i don't wanna have to come back and post
problems. I know someone will post teins are
the sht
Old Aug 29, 2005 | 11:04 AM
macDelli's Avatar
Default Re: (chinese acrobat)
teins are decent but gc is what i would go wiith especially in a crx youd have crazy handles
jshaw23
Jan 3, 2012 07:24 AM
Baggy Spandex
13
Apr 26, 2007 11:32 AM
Dave421
14
Mar 5, 2007 10:57 AM
EK4civichatch
Sep 24, 2004 02:06 PM
DIY_Racing
10
Jul 2, 2002 09:48 AM
