cluster lights...
before my cluster lights didn't work so i changed the fuse and only the right side of my cluster (gas, temp, and some of the mph) work, the rpms don't light up is their another fuse??
was the fuse u replaced blown? if it was a couple of lights could have gotten damaged, i think there is only 1 fuse, lights behind the cluster are easy to change
look for a diy thread on amber lights, that will show u how to change em
damn cuz the cluster is the jdm eg6 thast i just got.. when i had the stock cluster it didn't light up at all so i thought it was the lights.. but with my new one it dind't light up either so i changed the fuse, and now only half of the cluster is working..
sometimes the lights will do that, it is possible that its not getting a ground because they ground thru where it screws in at so if you hit the dash some times the lights will come on, i had that problem all the time in my old hatch. Its worth trying.
thanks ill check that 2morro.. the reason y i guess it might be the bulb is because i took the cluster out today and put it back in and the same thing happend... i guess wut i should do it put the old one in n see if everything lights upp... damn just mad lazy to do it.. lol
ok i just took my new cluster out n put the odl one in turns out i guess ALL the bulbs were out on my old one.. so im guessing i just need a couple of new blulbs for my new cluster.. can sum1 please tell me the specific bulb i have to get i have the eg6 jdm cluster that lights up amber are their just stock amber bulbs or do i have to color them like what i saw on the faq..
mrbsponge
Dec 31, 2003 03:31 PM
South Bay Surfer
Jan 23, 2003 03:12 PM
