Need some opinions on which tranny to go with....
Old Aug 26, 2005 | 05:56 PM
dynamyks's Avatar
Default Need some opinions on which tranny to go with....
okay heres my situation...i have a RS and my clutch needs to be changed very soon, its having trouble releasing so i cant shift right...and i plan on buying one some tym this week
ive been doin research on chaging my tranny and its between a GSR tranny or a B16 with LS 5th...
i kno its been covered many times before, but to you guys out there who hav actually done these types of swaps what are the pros and cons of each tranny?...and can any one confirm that the clutch im goin to get for my RS fit right in with either of these tranny's?.. does a vtec tranny hav any affect on a non vtec engine? ...thnx
Modified by dynamyks at 7:07 PM 8/26/2005
Modified by dynamyks at 7:08 PM 8/26/2005
Old Aug 26, 2005 | 06:59 PM
the_23rd_letter's Avatar
Default Re: Need some opinions on which tranny to go with.... (dynamyks)
correct me if im wrong but, i dont see why there would be any problems between the clutch and tranny, especially considering that the B-series trannys are interchangeable. im a bigger fan of the gsr tranny than the b16, its kind of the middle ground. eh just my .02
sam - who really enjoys the middle ground.
Old Aug 26, 2005 | 07:00 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamyks &raquo;</TD></TR><TR><TD CLASS="quote">i kno its been covered many times before, but to you guys out there who hav actually done these types of swaps what are the pros and cons of each tranny?...and can any one confirm that the clutch im goin to get for my RS fit right in with either of these tranny's?.. does a vtec tranny hav any affect on a non vtec engine?</TD></TR></TABLE>
Yes it fits, no there are no other effects. Search next time please.
Old Aug 26, 2005 | 10:52 PM
dynamyks's Avatar
Default Re: Need some opinions on which tranny to go with.... (Kendall)
i did search but there was a lot of pointless info to weed thro...and i did find my answer juss wanted to double check...well thanx bro ...also how can you tell the diffrence between the gsr and ls tranny?
Old Aug 26, 2005 | 11:14 PM
i know the s80 and y80 transmissions were used in the LS/RS/GS models but im not sure if its the same transmission code for the GSR, check the serial number (white sticker) on the transmission casing and if it doesnt begin with S80 or Y80 then you know its at least not an LS. otherwise youll have to count the number of times the input shaft rotates per revolution of the output shaft, do that for each gear and match them up with the GSR transmission gear ratio specs. unfortunately i get a feeling that you might have to do the latter of the two.
Old Aug 27, 2005 | 02:41 PM
dynamyks's Avatar
Default Re: Need some opinions on which tranny to go with.... (the_23rd_letter)
can any one else give me more info on this subject?
00civiccali
May 26, 2008 10:24 PM
slo_ej8
Apr 8, 2008 02:53 PM
slowcrx954
Jul 24, 2007 08:37 AM
6shootahorsenamedtrigga
Aug 8, 2004 11:17 AM
incognitoracerr
Feb 15, 2004 09:42 AM
