aftermarket calipers on stock rotors
Old Feb 25, 2002 | 05:57 AM
SOHCArchangel's Avatar
Default aftermarket calipers on stock rotors
quick question, is anyone running aftermarket 4-piston(or more) calipers on the stock size rotor? i.e wilwood etc..., if so what model etc....TIA
Old Feb 25, 2002 | 06:13 AM
AssPenny's Avatar
Default Re: aftermarket calipers on stock rotors (SOHCkordVTEC)
Spoon 4-pots bolt right up and take the same size pad as the stockies.
Old Feb 25, 2002 | 06:15 AM
Bbasso's Avatar
Default Re: aftermarket calipers on stock rotors (AssPenny)
AssPenny is it worth the money for the shorter stopping?
Old Feb 25, 2002 | 06:16 AM
Default Re: aftermarket calipers on stock rotors (Bbasso)
yeah man, really, my spoon clutch line was pretty pricey already , any one else?
Old Feb 25, 2002 | 07:27 AM
Initial_E's Avatar
I am running Endless caliper with 6 slots (stock size) Endless rotors.
[Modified by Initial_E, 9:06 AM 2/25/2002]
Old Feb 25, 2002 | 07:45 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
It doesn't improve the stopping distance by a whole lot. But it allows very precise modulation of your brakes and even wear of the pads, which are the main purposes of multi-piston calipers.
Old Feb 25, 2002 | 07:50 AM
AssPenny's Avatar
Default Re: aftermarket calipers on stock rotors (Wai)
Ask Dave-ROR, D and Yack if it makes a difference. I would say deffently yes. Also the CCX pads help out alot too
Cosworth's Avatar
How much difference came from CCX pads? Did you ever run the calipers w/ stock pads?
Old Feb 25, 2002 | 07:57 AM
Wai's Avatar
Wai
Pads make a bigger difference in stopping distance than the calipers. I have the Spoon brakes myself. It does make a difference in stopping distance but honestly not by a whole lot. But the ability to modulate the brakes worths much more than the ultimate stopping power IMO.
Old Feb 25, 2002 | 08:01 AM
AssPenny's Avatar
Default Re: aftermarket calipers on stock rotors (Cosworth)
Never ran them with the stock pads. I modified the stock pads to work with the Spoon calipers and was going to install them after the final drive install, but as you all may know, I ran into a few other problems and have now been with out a car for over a month.
Old Feb 25, 2002 | 08:08 AM
Bbasso's Avatar
what i meant by "AssPenny is it worth the money for the shorter stopping?" the cost of changing to 4pot and pads aint cheap, right? so the feel of the brakes & distance is much better but at what cost?
would any of us just be better off with ss lines and fantastic pads? (cost effective)
Old Feb 25, 2002 | 08:10 AM
AssPenny's Avatar
It would have been more cost effective to just go SS and pads, but I plan on road racing alot in the near future and got a good deal (at the time) on the calipers. Right now, I don't feel it was worth the money as I don't track the car at all, but when I start, I'm sure it will be worth it.
Old Feb 25, 2002 | 08:14 AM
Cosworth's Avatar
Holy... it's already been over a month!?!
Old Feb 25, 2002 | 08:21 AM
Bbasso's Avatar
if ya going hardcore racing sure!, but for the streets and very few track events maybe if money was no object
I got ya
xbB
Oct 31, 2004 06:41 AM
shinchan
Mar 27, 2003 11:12 AM
itrsport.com
Jun 17, 2002 08:27 AM
shamoo
25
May 31, 2002 09:54 PM
