Need help with these motor mounts....
I have 2 sets of motor mount inserts from Energy Suspension (3 torque mounts).
I bought the second set because I forgot that I had purchased some in the past and were sitting around in a box. So that's why have 2.
But the problem now is that I've noticed that the 1st one I got are 16-1106G (Black) and the second one I purchased last night were 16-1106R (Red).
Now, I'm confused...
Why is one G and other R. One black and the other Red? What is color difference?
Nevermind, I found out the difference....the letter at the end of the part number determines the color....G (Black) R (Red)......
Thank you and have a good day!!!
Energy Suspension Motor Mount Inserts for Acura/Honda
View larger image
Product images may differ from actual product appearance.
For front wheel drive vehicles. These mount inserts are thoroughly tested to add support and stability to the existing O.E.M. motor mount system. They both restore worm mounts and reduce unwanted movement. Under high performance condition, they reduce wheel hop and torque induced movement that can damage components.
Colors Available:
These motor mount inserts are available in (G)=Black, (R)=Red, and (Y)=Yellow. Watch for these letters at the end of each part number below.
View larger image
Colors Available:
AllMotorITR
Nov 22, 2001 04:37 PM
