b16a swap question
Old Aug 26, 2005 | 01:05 PM
aznej2's Avatar
Default b16a swap question
recently swapped a b16a into a civic dx coupe... vtec crosses over and everything. but motor wont go past 7500 rpm... to my knowledge it should b able to reach 8200. any ideas?
Old Aug 26, 2005 | 01:08 PM
komat's Avatar
Default Re: b16a swap question (eg_6_racer)
what ecu are you using
and are you throwing any cel
when you say it wont go pass 7500 its hitting the rev limiter?
Old Aug 26, 2005 | 01:11 PM
aznej2's Avatar
Default Re: b16a swap question (komat)
using p30 (purchased complete swap from hmotors) only thing i can think of is knock sensor is not wired yet. yep.. 7500 is rev limiter
Old Aug 26, 2005 | 01:13 PM
komat's Avatar
fix all your cel then test it again
knock sensor only takes 5min to hook up to ecu
Old Aug 26, 2005 | 01:18 PM
Shaun's Avatar
whats the cel ??
Old Aug 26, 2005 | 01:46 PM
EG6_GUY's Avatar
I ran into the same problem after my sir2 swap. It turns out my tach was not properly calibrated and was just way off. I hooked up a VAFC and the rev limit was fine. Replaced my Si meter panel with an Sir2 one. Much better!
Maybe this helps, maybe not.
Faayde
34
Oct 3, 2015 07:51 PM
teggsr925
68
Mar 6, 2010 07:00 AM
drewb16a
Dec 26, 2007 05:32 PM
b18 EK9
Jun 18, 2007 03:21 PM
aznej2
Oct 10, 2005 09:42 PM
