i Broke My CRX in under a week
Old Aug 26, 2005 | 08:00 AM
nicholai's Avatar
Default i Broke My CRX in under a week
ok i bought a 91 crx i was drving it and all of a sudden the rpm dropped then the car died i was like hmmm wtf i tried to restart it 0 power what so ever so i go look and the battery cable fell off and htt the frame... now the car wont restart but it cranks.. i get sparks i checked all the wires and plugs timeing is ok but it is getting fule cuase i could smell it in the cylinders ... what could be the problem... something had to of shorted out but what?
Modified by nicholai at 9:27 AM 8/26/2005
Old Aug 26, 2005 | 08:34 AM
djsire's Avatar
Default Re: i Broke My CRX in under a week (nicholai)
check the fuses under your dash and in the engine bay by the battery. you prolly blew them
Old Aug 26, 2005 | 08:36 AM
nicholai's Avatar
Default Re: i Broke My CRX in under a week (djsire)
there all good i checked them all
Old Aug 26, 2005 | 08:45 AM
CRX Toad's Avatar
Check positive battery cable for corrosion. It will corrode inside the insulation and then after sometime is just stops.
Old Aug 26, 2005 | 08:48 AM
nicholai's Avatar
Default Re: i Broke My CRX in under a week (CRX Toad)
no thats good too oh i forgotto mention there is also a short somewhere the baterry keeps drainning itself overnight. i never had any of these problems till that cable fell off and hit the frame...
Old Aug 26, 2005 | 08:57 AM
xagix's Avatar
If the motor is cranking over then it has to be something electrical.
Check your coil in the dizzy and see if it's toasted. If not just go over all your sensors. Also check your ecu, you might have had a send back in power. Are you throwing any codes?
Old Aug 26, 2005 | 09:12 AM
nicholai's Avatar
Default Re: i Broke My CRX in under a week (xagix)
its fine i thik my injectors are STUCK open i am getting way to much fule inside to the point were its flooding out the exsuast and it fireballs hahaha
Old Aug 26, 2005 | 03:31 PM
SETI20's Avatar
Your injectors probably aren't open, you're not getting enough spark. Check your grounds, those can cause weak spark. Your dizzy might be fried... stuff like that.
Old Aug 26, 2005 | 05:12 PM
nobigtoe's Avatar
witch battary cable fell off. more importantly is your battery tied downed. i have neve had a battery cable fall off
Old Aug 26, 2005 | 05:32 PM
crexer's Avatar
Default Re: (nobigtoe)
I would be willing to be its the ignitor or coil inside the distributor
Old Aug 26, 2005 | 07:01 PM
SomeDude56's Avatar
Zero power? if its that its main fuse...... top left of battery in little black box....u can c if there blown. gl
Old Aug 26, 2005 | 07:31 PM
91 crx savage's Avatar
did u fry the ground to the valve cover?
Old Aug 27, 2005 | 10:40 AM
nicholai's Avatar
it was the postive cable its not the main and the battery is in the trunk.. all fuses are ok dizzy is ok
Old Aug 28, 2005 | 10:45 AM
nicholai's Avatar
Default Re: (nicholai)
i finally gave up i took it to the shop and dropped it off told them to fix it .... DUN DUN DUN
Old Aug 28, 2005 | 11:27 AM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nobigtoe &raquo;</TD></TR><TR><TD CLASS="quote">witch battary cable fell off. more importantly is your battery tied downed. i have neve had a battery cable fall off</TD></TR></TABLE>
i have. I had never seen anything like that happen before it. I was driving to Chicago and when i would hit the brakes at idle the check engine light would come on and the radio would cut out. I was freaking out. I had just done some wire tucking too the previous night and actually finally installed my battery tie down so i had reason to worry. Got to school, parked the car. Turned it off and tried to restart it. Click. Pop the hood and the negative battery cable was laying next to the battery.
The terminals on both of my CRX's are to the point where you can't tighten them down anymore though. I was going to put new ones on (actually have them) but i'm going to relocate my battery so i'm dealing with it until then.
Old Aug 28, 2005 | 03:50 PM
nicholai's Avatar
Default Re: (njn63)
mine is in the trunk
Old Aug 28, 2005 | 04:15 PM
NikoZai's Avatar
for future reference, in order for honda-tech members to help you, you have to give alot of information about what is wrong with your car.
Otherwise you'll always be the guy spending $100+ at a shop to fix something you could have fixed yourself in 5 minutes, if you had just been clear about what was wrong with what part.
Better luck next time. Shops, in my opinion, aren't that great and usually just rip people off. I know because we have 4 customers a week come to us with bad information that was given to them, by a shop.
Old Aug 28, 2005 | 04:27 PM
nicholai's Avatar
um if i knew what part i would of said it.....i gave a desciption of what happned becase thats all i no....
Old Sep 5, 2005 | 01:02 AM
nicholai's Avatar
i finally got the car back from the sop and it ran fine for the day then it over heated.... n its fucked up now.... it loses half its power at low rpm when moveing have to literally floor it to make it move 20mph
jamzx3
13
Sep 19, 2011 09:49 PM
9.3.S.I.L.U.D.E.
Oct 6, 2010 09:52 AM
rSol93
13
Jul 5, 2008 12:22 PM
elrandeeto
Aug 8, 2005 11:37 AM
gumbybum
Feb 8, 2003 11:25 PM
