b18a block
Old Aug 25, 2005 | 10:54 PM
spazz0nater's Avatar
Default b18a block
just got a b18a block, what would be the best head and best tranny for this setup and any body know good write ups on the net on this?
Old Aug 25, 2005 | 11:10 PM
Default Re: b18a block (spazz0nater)
nvrmnd got a b18a too just need on the ecu and tranny for install on a 90 civic hatch plz
Old Aug 25, 2005 | 11:34 PM
gen2fanatic's Avatar
lets see, im doing the same exact build up...
you got a b18a obd-o motor so heres what you need...
LS tranny (ys1)
pr4 obd-o ecu
88-91 civic b series swap motor mounts
you will have to cut the shift linkage and weld together ( or buy from jdmshit.com)
figure out what engine harness you want to use and figure out how to wire it up
i know im probably forgettig something, but thats basicly what you need...
how many miles on motor??
Old Aug 25, 2005 | 11:41 PM
Default Re: b18a block (gen2fanatic)
no idea but rebuilding it
what other trannys bolt up?
and what options do i have on harneses
And what about the axles?
Old Aug 26, 2005 | 12:23 AM
TH33G4MON3's Avatar
good luck always wanted to build that motor up keep us updated on how it goes
Old Aug 26, 2005 | 01:21 AM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spazz0nater &raquo;</TD></TR><TR><TD CLASS="quote">no idea but rebuilding it
And what about the axles?</TD></TR></TABLE>
Any b series tranny bolts up. The harness depends on what model car you have. The axles I have no clue because I'm using aftermarket ones.
Old Aug 26, 2005 | 09:49 PM
Default Re: b18a block (michaelOlson)
i have herd that 90-92 teg axles work on a b16 tranny so should that work for this too? It's non vtec so is there much modification to the harness?
Old Aug 26, 2005 | 11:04 PM
g-ride-si's Avatar
What model hatch do you have? If its an si then the harness is plug and play. DX or STD you will need to do the dpfi to mpfi swap. I used 90 teg axles. I have the ecu you will need (OBD-0 PR4). Got any questions you can pm, me ive done this swap a cpl times.
Old Aug 29, 2005 | 08:59 PM
Default Re: (g-ride-si)
ya i have an si, and is there any chance there is a obd1 ls? but other then the mounts it's just a drop in thing nothing big?
Old Aug 30, 2005 | 12:19 PM
g-ride-si's Avatar
the wiring is nothing to be worried about. If the motor is obd1 then it will take more work. If the motor is a 90 or 91 b18a then its obd-0, if its 92-93 then its obd-1. So if its a 90-91 b18a its plug and play.
Like stated above you will need; mounts and shift linkage for a b series swap, motor, b series cable tranny(unless u get the hydro conversion kit), axles, ecu. Then you need to learn whats involved in the swap. You will need to get in the engine bay with a hammer and beat the crap outta some stuff for clearance reasons.
Old Aug 30, 2005 | 02:31 PM
civickiller's Avatar
you also need a b series fuel line. i just did an ls swap in my car and converted it to obd1 but this was with a 96 obd2 ls engine. you may need a integra cable for the clutch, integra throttle cable would look better.
b16 tranny would be best cause it would be the fastest. i used 90-93 teg axles but i was using a 90-93 teg intermdiate shaft.
Old Aug 30, 2005 | 02:49 PM
g-ride-si's Avatar
ya, i used the the stock civic clutch cable and just cut the plastic sheath back about an inch. used the integra throttle cable. I dont really know what you mean by the b series fuel line? i didnt change any fuel lines on any of the ls swaps ive done. but they have all been obd-0. If you got an obd 1 motor it will be easier for you to just convert the motor to obd-0 all you need is 90-91 teg injectors and dizzy.
Old Aug 30, 2005 | 04:42 PM
sorry about the fuel line, i was thinking of my dpfi. but his is an si right. as far as the clutch cable, my stock clutch cable worked, idk if that means its stretched out or anything but yeah.
but if he converts to obd0 from an obd1, since he has the stock motor, all he needs is the dist. because you can use any obd for injectors and since he has his stock 1 wire o2 that can swap over, so all he needs is a obd0 teg dist
Old Aug 30, 2005 | 06:13 PM
HondaCivicSiR1's Avatar
Default Re: (civickiller)
pm 'd you
Old Sep 3, 2005 | 08:04 PM
lazyboy's Avatar
i am also doing this swap and i have an si and a 90 ls integra motor and i need b series motor mounts if anyone has them and need a pr4 but i need help also so im gonna use this thread as a guide because ive never owned a honda till about three days ago(not tryin to be a post *****)
Old Sep 3, 2005 | 09:35 PM
UsDm_Junky's Avatar
anybody have any comments on a ls/vtec with a b16 tranny? im going all motor with that setup what things should i do to make it competitieve such as cams and pistons etc. thanks
Old Sep 4, 2005 | 11:09 AM
g-ride-si's Avatar
Default Re: b18a block (lazyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyboy &raquo;</TD></TR><TR><TD CLASS="quote"> and need a pr4</TD></TR></TABLE>
I got one if u wanna buy it. Its out of a 90 ls 5 speed. I can also help u with the swap if u wanna pm me
Old Sep 4, 2005 | 10:27 PM
UsDm_Junky's Avatar
bump for help
Old Sep 5, 2005 | 11:54 AM
lazyboy's Avatar
Default Re: b18a block (g-ride-si)
ight man anything helps, how much are you looking to get for the ecu and do you have an si wiring harness by chance my harness is jacked up and i dont exactly know how to pm anyone on this site
Old Sep 5, 2005 | 02:44 PM
g-ride-si's Avatar
no harness just give me an offer and we can work it out, I have paypal and if you want it ill plug it into my car to make sure its still working fine.
If you wanna pm you click on the user's name that u want to talk to then click send instant message. To check your instant messages click on My Profile at the top right of the screen then click on Instant message history.
Old Sep 5, 2005 | 06:10 PM
lazyboy's Avatar
thats what i thought but i cant pm anyone cuz im in trial mode but ill talk to my freind chris and have him do all the stuff
Old Sep 5, 2005 | 08:14 PM
K im going to try to take my thread back!
Going to get the motor tommorow going to post pics.
Still need:--
Axles and intermidiate shaft 90 teggy
ls tranny
88-91 b series mounts
88-91 b series shift linkage
maybe sensors and **** dont know what it will have on the motor
Maybe exhuast manifold
Money
Old Sep 5, 2005 | 08:38 PM
lazyboy's Avatar
Default Re: (spazz0nater)
sorry man im just in the same boat as you with the sawp taking place in a week or two with no way to pm anyone or anything like that but good luck with the swap sorry for being a *****
lilredrocket83
Jan 21, 2008 05:24 PM
Specialk
Apr 8, 2007 08:58 PM
SQ is the SQUAD
Apr 28, 2006 04:18 AM
blackdude
Feb 22, 2006 09:09 AM
dosJDM
Jul 19, 2002 01:10 AM
