90 - 93 integra fog light problems
Old Aug 25, 2005 | 10:38 PM
acuraocd's Avatar
Default 90 - 93 integra fog light problems
fist off i have a 90 acura integra in the making.... i installed jdm one peice head lights in it... i have installed these headlights maybe 10 times.. never had a problem.... now this time everything worked fine after i installed the... foglights,head lights, high beams, turn signals.... it all worked... then i brought the car down to my buddys shop to get an alignment... and when he was backing upi noticed the fog lights weren't on..... now with the jdm headlights... the thing i like most is the orange fog lights and so naturally i go to put them on... they didn't turn on so i checked the fuse and it was blown.... now every time i put a fuse in and press the fog light switch... i blow a fuse....
if anyone has anything on this subject.. please post...
pics of the project.... pics updated usally 2 times a week
http://community.webshots.com/...lawEX
Old Aug 25, 2005 | 11:08 PM
SpoonTeg's Avatar
Default Re: 90 - 93 integra fog light problems (acuraocd)
sounds like a ground wire rubbing up on the chassis.....check the headlights for a loose connection or open wires.... usually thats the case....thats why it blows liek that
Old Aug 26, 2005 | 05:25 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
http://www.g2is.com might have some answers for you too...
Chris
Modified by DAantagonist at 11:43 AM 8/26/2005
Old Aug 26, 2005 | 06:45 AM
awps's Avatar
Default Re: 90 - 93 integra fog light problems (DAantagonist)
that would be http://www.g2ic.com
Old Aug 26, 2005 | 07:43 AM
Default Re: 90 - 93 integra fog light problems (awps)
shame on me...I apologize....
Old Aug 26, 2005 | 02:04 PM
1.6-16 INTEGRA's Avatar
You might wanna try checking your main relay fuse also. It should be located under the dash. Just above the pedals. It's a black box and is about 2-3 in. Due to the age of our DA's these usally go out and may need to be replaced.
Old Aug 26, 2005 | 02:30 PM
temp's Avatar
Default Re: (1.6-16 INTEGRA)
http://www.g2ic.com/tegtips/lighting/6.html
Old Aug 26, 2005 | 07:03 PM
LeftCorner's Avatar
Default Re: 90 - 93 integra fog light problems (SpoonTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonTeg &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a ground wire rubbing up on the chassis</TD></TR></TABLE>
Ground wire is suppose to go to the chassis. Check the red/blue and red/black wires that go to the foglights and make sure they're insulated properly. There's most likely an open spot from your splice that may be touching metal causing a short.
Old Aug 26, 2005 | 08:28 PM
_KaiZeN_'s Avatar
Default Re: 90 - 93 integra fog light problems (LeftCorner)
dido...
4serioferio
Aug 13, 2012 03:30 PM
HondaVerno
May 1, 2010 09:08 PM
9.3.S.I.L.U.D.E.
Lighting
Sep 5, 2009 07:06 PM
jsen93ITR
Feb 14, 2008 07:46 PM
mister_r0b
Jul 16, 2004 10:42 AM
