d-series tranny question.
Old Aug 25, 2005 | 10:08 PM
brad 1.cam's Avatar
Default d-series tranny question.
ok i just got a new car (95 ej1) its the d16z6 and the only mods are 2.5 inch piping and a es oval muffler. i am planning on going turbo very soon. but my problem is my tranny, for one it grinds third gear so that gives me reason to replace it and what i want to know is whats the best d-series tranny i should use, i want something geard more for acceleration. cuz it seems like after 3rd gear it doesnt pull at all you know. so whats the best tranny swap i should consider?
Old Aug 25, 2005 | 10:12 PM
95dxhatch's Avatar
same tranny you got now is the best one to use.
Old Aug 25, 2005 | 10:15 PM
brad 1.cam's Avatar
Default Re: (95dxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxhatch &raquo;</TD></TR><TR><TD CLASS="quote">same tranny you got now is the best one to use.</TD></TR></TABLE> theres no way this is the "quickest" d-series tranny
Old Aug 25, 2005 | 10:22 PM
kkim's Avatar
Default Re: d-series tranny question. (brad 1.cam)
http://forums.hondashowoff.com...&st=0&
Old Aug 25, 2005 | 10:35 PM
brad 1.cam's Avatar
Default Re: d-series tranny question. (kkim)
haha damnit i guess it is, but then how much do they usually go for? im sure buying a differnet tranny will be cheaper than fixing it?
Old Aug 25, 2005 | 10:45 PM
kkim's Avatar
I've seen them go from $50-200.. depends on condition and what the seller thinks it's worth. Check out what's available on ebay to get a rough idea.
Old Aug 25, 2005 | 10:46 PM
brad 1.cam's Avatar
aight
Old Aug 25, 2005 | 11:50 PM
sohcvtec1995's Avatar
Just put some Syncro mesh in there. then see if that works.
Old Aug 25, 2005 | 11:51 PM
Oh and here is the poll of people who have noticed a difference with the syncro mesh. And it also labels different types.https://honda-tech.com/zerothread?id=677571
Old Aug 26, 2005 | 10:52 AM
cjkdelsol's Avatar
When you get the tranny you should break it open and replace the input shaft bearing. D-series are notorious for that bearing going out. It happened to me twice.
Old Aug 28, 2005 | 06:33 AM
Mista Bone's Avatar
D Tranny Guru
Define the grind.........
all the time or under hard driving?
above 3500 rpm?
Engine mounts and crappy shift bushings are the first cause, then a 1-2 broken shifter fork.
For boost/juiced the gearing in the EX/Si tranny is perfect.
Old Aug 28, 2005 | 06:46 AM
civicboisi's Avatar
Default Re: (Mista Bone)
^ so wouldnt the hybrid d series tranny be more effecient Mista?
Old Aug 28, 2005 | 06:59 AM
Mista Bone's Avatar
D Tranny Guru
not for boost or juice.........
fitting a .9375 CRX 4th would help, but the hybrid tranny is too close for higher powered cars.
My little 145 chp/121 whp D15Beast7 loves it though.
Old Aug 28, 2005 | 07:08 AM
civicboisi's Avatar
heh i thought the same...but wasnt too sure...nice info
Old Aug 28, 2005 | 08:37 AM
moto1320's Avatar
Default Re: (civicboisi)
Have you checked your clutch hydraulics for leakage?
Old Aug 28, 2005 | 08:42 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (moto1320)
that would effect all gears, not just 3rd.
Old Aug 28, 2005 | 09:27 AM
moto1320's Avatar
Not true, seen it many times. Third may have( and commonly does) it's own issues. However, if the hydraulics are just starting to leak then they progressively lose pressure in the quick 1-3 shifting process making the first grind happen there. Will third probably go out if this is the case later,yes. But he needs to do this simple check regardless of wether or not he gets a new tranny.
I'm talking first stages of leaks that haven't lead to perceptible pedal presure loss yet.
Old Aug 28, 2005 | 11:26 AM
brad 1.BANNED's Avatar
yea the pedal feels fine and all other gears shift smooth as pie anything over like 2500 rpms grinds, haha but who shifts into third at 2000rpms well im going to pick a bottle of synchromesh and see how that goes
Old Aug 28, 2005 | 01:51 PM
Mista Bone's Avatar
D Tranny Guru
how is the 3-2 downshift?
sounding like broken/worn 1-2 shifter fork, quite common.
Old Aug 28, 2005 | 03:19 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (brad 1.BANNED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brad 1.BANNED &raquo;</TD></TR><TR><TD CLASS="quote">haha but who shifts into third at 2000rpms </TD></TR></TABLE>
I do.
Old Aug 28, 2005 | 04:20 PM
moosepoop21's Avatar
screw it drop a b serious engine in there lol
Old Aug 28, 2005 | 06:09 PM
moto1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">how is the 3-2 downshift?
sounding like broken/worn 1-2 shifter fork, quite common.</TD></TR></TABLE>
OT but I'm interested...have you actually had one break? Mine were worn very badly on my first re-build but I hadn't come across one in the shop snapped yet.
Back on topic...are you getting any noise from the tranny at idle. Another grind issue that I see before synchros are from shot input shaft bearings. If you can't tell I'm decidedly NOT on the Syncromesh bandwagon at all and try to rule out everything else.
Old Aug 29, 2005 | 11:16 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (moosepoop21)
shadup unless you have something useful to add
Old Aug 29, 2005 | 02:51 PM
nope no other problems besides 2-3, idleing is fine all other shitfs/downshifts are fine.
Old Aug 29, 2005 | 04:11 PM
moto1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">shadup unless you have something useful to add </TD></TR></TABLE>
I hope that wasn't directed at me. There is nothing on his entire car I couldn't fix, it's what I do 12 hours a day. What's wrong with me asking for more details? Hard to be useful until you have the info.
