Mini me spark plugs/timing?
Old Aug 25, 2005 | 08:52 PM
shbrown's Avatar
Default Mini me spark plugs/timing?
I have a A6/Z6 mini me. The head was milled a bit before I put it on, so I guess my compression is pretty high. I was wondering if I should be using colder plugs. I notice a lot of ticking in hotter weather under high load, and I am guessing this is detonation? Would colder plugs help? And if so, which ones should I get?
Also, should I have the ignition timing set to A6 or Z6 specs? I used A6 because I have the A6 crank pulley and helms manual, but I was thinking lately that the Z6 specs make more sense. What do you guys think?
-S
Old Aug 26, 2005 | 06:48 AM
shbrown's Avatar
Default Re: Mini me spark plugs/timing? (shbrown)
Please help, I was hoping to work on my car this weekend, and wanted to get these two issues dealt with... I have searched but did not get any conclusive answers...
Old Aug 26, 2005 | 07:31 AM
EJ2-Fluffy's Avatar
Use the Z6 specs for timing. Just use the stock spark plugs. Works fine for me.
Try doing a valve lash adjustment as well.
Intake = .007-.009 inches
Exhaust = .009-.011 inches
-Jon
Old Aug 26, 2005 | 07:37 AM
d357r0y's Avatar
I had a y8/a6 mini-me and used a 1 step colder plug and had zero problem.
As far as timing, I thought all the Ds were set at 16°btdc?
Old Aug 26, 2005 | 08:10 AM
shbrown's Avatar
Thanks guys.
I did a valve adjustment when I first put it together, but I should probably do it again.
For timing, I was under the impression that the Z6 was 20 btdc, and the A6 is 16. I pulled the A6 # from Helm's, but not sure about the Z6.
For one step colder plugs, does anyone have the NGK #? Or a link that describes the codes?
Thanks!
Old Aug 26, 2005 | 10:48 AM
d357r0y's Avatar
Default Re: (shbrown)
the auto parts store should be able to look up the next coldest plug (thats how i did it)
Old Aug 26, 2005 | 11:37 AM
CRXDrew's Avatar
i hope you have a cam gear to make up for the difference between the a6 and z6 heads... not to mention the lil difference that can be accounted for by the milling.
I believe I zero'ed out the head to the block somewhere around 5degrees retarded on the cam.
Old Aug 26, 2005 | 04:19 PM
shbrown's Avatar
I was going to get a Y7 cam gear and use that... I heard that will give me the half tooth difference I need... It seems to be exactly a half tooth off right now. (cam retarded) Would that cause detonation?
DaCivicSWAP
Jun 14, 2012 12:56 PM
dirvin7588
May 8, 2011 08:13 AM
87shytwhip
May 6, 2008 08:45 PM
CRXCRAZYD16Y8
Feb 28, 2006 11:39 AM
robtec
Jan 14, 2004 07:32 AM
