Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating
Old Aug 25, 2005 | 08:52 PM
JibOnALib's Avatar
Default Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating
Hi, I just swapped a gsr into my 94 Si, and I'm throwing only a code 41, when i'm at low rpms and get on it a little the car bogs down and then i let off and slowly accelerate its fine. The o2 sensor has quite a bit of mile on it, do you think a bad o2 could cause the car to bog like it does when you accelerate?
Thanks,
Keith
Old Aug 25, 2005 | 08:54 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating (JibOnALib)
Change the o2 sensor and find out, and yes the o2 sensor can cause hesitation
EK k kay's Avatar
Default Re: Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating (MugenHonda)
Check the primary o2 sensor connection. Might have gotten loose somehow. If that doesn't work just replace it.
924drb20
Dec 14, 2010 10:36 AM
Bossup!
Sep 9, 2009 07:35 PM
claytonsmith
10
May 16, 2006 12:01 PM
draxxus07
Oct 13, 2005 05:41 PM
