HELP!!!!! Engine Mount inserts
Old Aug 25, 2005 | 08:44 PM
TA Performance's Avatar
Default HELP!!!!! Engine Mount inserts
i heard that having stiff mounts will make u put more power to the ground and all, but since i installed my energy suspension motor mount insert for the lower tourqe mounts my car feels slower and idles very ruff making the car vibrate as if u were sittin in a massage chair. Just want some info from you tech guys out there! could there have something gone wrong? Car always used to break traction in 1st and 2nd gear at 5 psi
Thanks
Old Aug 25, 2005 | 10:58 PM
jdm4life!'s Avatar
Default Re: HELP!!!!! Engine Mount inserts (TurboSpirit_DC2)
hey. ok the vibration problem is common. you cant avoid it! the old rubber bushings used to act like a shock and absord most of the vibration. the polyurethane bushings are hard so they transfer power better but consequently also transfer the vibration.
Old Aug 25, 2005 | 11:47 PM
Default Re: HELP!!!!! Engine Mount inserts (jdm4life!)
whats the cause for the car feeling slower?
Old Aug 26, 2005 | 05:41 AM
v4lu3s's Avatar
RTFM
its in your mind most likely. unless you knocked charge pipe connections loose etc. i have found that a stiffly mounted engine puts power to teh grund better and is a little less likely to break traction since everything isnt fighting under the hood and moving around.
Old Aug 26, 2005 | 07:04 AM
kameleon23's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">its in your mind most likely. unless you knocked charge pipe connections loose etc. i have found that a stiffly mounted engine puts power to teh grund better and is a little less likely to break traction since everything isnt fighting under the hood and moving around.</TD></TR></TABLE>
Civic168
Suspension & Brakes
Mar 3, 2006 09:46 PM
BobGnarly
Feb 12, 2005 01:15 PM
TurboTagTeam
11
Dec 24, 2004 12:00 PM
Patron
Jan 18, 2003 06:28 AM
B18C
Oct 16, 2001 12:42 PM
