Spark Plugs
Hey guys I am new to the board, so if this was already talked about then I apoligize. I am wondering how much of a "gap" is required for spark plugs on a 98 LS. How exactly do you install to the gap and all. I really do not wanna mess up my car, and I figured most of you would know this better then me! So I guess my question is, how do I install new spark plus the RIGHT way. Any help is appreciated, thanks again....
i dont have an LS so i dont kno it might be 0.44.. but if you pop your hood and look under it.. there should be an emissions sticker which tells you what plugs to use and what gap, and other info on your car i think... also you could look in your owners manual for the specs on gap, torque spec, and what plugs to use..
my 94ls plug gap is 1.1 mm...very simple to do. just don't over tighten it or you are going to mess up your cyl head. there are instructions on the spark lug box...
Thanks guys I'll check it out. I was just worried about tightening and how to measure it so it's not too tight. I'll check the manual and what not and then we'll see how it goes.
most plugs are factory gaped these days...my bosch+4 were i know that
So NGK spark plugs are the best way to go?? I am gonna be picking these up tomorrow and hopefully installing em too. So I just use torque em to whatever it says under my hood? A few turns....
i have the same question.
how do i know if i installed the plugs right?
what would happen if i fastened them too tight, so
i could know i did it wrong?
thx
thx
-Chet
If you don't have a torque wrench (go buy one for $70 and consider what you saved by not going to the dealer as payment on the wrench), then tighten the plugs until you just meet resistance, then give it a quarter turn more.
Alright NGK it is! In another post there was someone saying that copper plus give more power, but platinum lasts longer. I think that's what it was....
civic_driver
11
May 29, 2009 06:00 PM
