oil change
Old Aug 25, 2005 | 07:35 PM
Jordans95si's Avatar
Default oil change
im changing my oil for the first time, what oil, mobil 1? what kind? and im going up to honda dealership to get filter,
Old Aug 25, 2005 | 09:39 PM
honda3431's Avatar
Default Re: oil change (Jordans95si)
I went mobil 1 synthetic... but remember, once you use synthetic, your not supposed to go back. And if your car eats any oil, you might be better off with somethin a little cheaper.
Old Aug 25, 2005 | 09:54 PM
bad-monkey's Avatar
Default Re: oil change (honda3431)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda3431 &raquo;</TD></TR><TR><TD CLASS="quote">I went mobil 1 synthetic... but remember, once you use synthetic, your not supposed to go back. </TD></TR></TABLE>
Totally Untrue Myth.
Old Aug 25, 2005 | 09:57 PM
The Phil's Avatar
I want to find whoever started that and shoot them.
The dude at advance auto scolded me for buying dino oil last time I was there. He was like, "you've been buying synthetic for awhile. You can't put that in your car anymore."
Just get generic 10w30 and a k&n gold filter.
Old Aug 26, 2005 | 07:25 PM
Bror Jace's Avatar
Default Re: oil change (The Phil)
I change from mineral to synthetic and back again with the passing seasons. Not a pronblem to date and it's been decades.
Old Aug 27, 2005 | 07:18 AM
JakeD's Avatar
I wouldnt waste your money on mobil 1 with your setup. I would buy Valvoline 10w30 and the cheapest filter you can get your hands on.
Old Aug 27, 2005 | 08:45 AM
Default Re: oil change (JakeD)
should i pull out the filter first or the drain plug?nvrmnd that didn't sound right,lol
Old Aug 27, 2005 | 08:50 AM
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordans95si &raquo;</TD></TR><TR><TD CLASS="quote">should i pull out the filter first or the drain plug?
lol drain
Old Aug 27, 2005 | 11:27 AM
JakeD's Avatar
yeah drain is the "correct" way to go first but it really doesnt matter, most of your oil will be in the oilpan anyway.
Old Aug 28, 2005 | 03:52 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeD &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt waste your money on mobil 1 with your setup. I would buy Valvoline 10w30 and the cheapest filter you can get your hands on.</TD></TR></TABLE>
Mobil 1 is NEVER a waste in any engine...
(unless the engine a) doesn't run or b) hemmorhages oil.)
Old Aug 28, 2005 | 05:35 PM
georgiajdm's Avatar
Default Re: oil change (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
(unless the engine a) doesn't run or b) hemmorhages oil.)</TD></TR></TABLE>
true, my moms 89 maxima on mobil one went 280,000 before the valvesprings cracked the a torqueconvertor shattered.
i changed to mobil 1 after just 500miles on my 2001 prelude, did a compression check a month ago w/ 30k miles and it read 220psi on all cylinders.
Old Aug 29, 2005 | 07:41 AM
turboH22Aakkord's Avatar
AMEN...... and i think its a good idea and recomneded to use the mobil 1 filter whenever you use synthetic oil... regular filters dont have the correct filtering for synthetic oils... (correct me if im wrong...)
Old Aug 29, 2005 | 10:20 AM
honda3431's Avatar
Default Re: oil change (turboH22Aakkord)
Well, Mobil 1 seemed to have been a good choice for me then. But I don't have a Mobil 1 filter in... maybe I will get one and get rid of the fram that is in there.
Old Aug 30, 2005 | 06:57 PM
Bror Jace's Avatar
" ... and I think its a good idea and recommended to use the Mobil 1 filter whenever you use synthetic oil... regular filters dont have the correct filtering for synthetic oils... (correct me if im wrong)"
OK, I will. The filter doesn't know nor care what kind of oil you are using ... mineral or synthetic (and these days, some synthetics are actually mineral oil anyway).
The Mobil 1 filter is what's called a "high-efficiency" filter. It uses a dense filtration media which can be restrictive to proper oil flow in certain applications. Purolator Pure-One and Amsoil filters also use a very dense media.
Mobil 1 filters ARE well-made, however. They are one of the highest quality filters made by Champion Labs in New Jersey. Champion Labs also make Bosch, Lee, K&N and SuperTech (Walmart brand).
But I still wouldn't use them ... especially considering the price.
Old Aug 30, 2005 | 08:10 PM
bad-monkey's Avatar
I generally use the fram X2, the only filter fram makes that's worth buying...
Old Sep 1, 2005 | 06:01 PM
omgdudewtf's Avatar
bobistheoilguy.com
do some research for yourself. i'm so tired of people talking about motor oils when the only thing they know about it is what they were told. lame.
Old Sep 2, 2005 | 07:45 AM
Default Re: oil change (Bror Jace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bror Jace &raquo;</TD></TR><TR><TD CLASS="quote">" ... and I think its a good idea and recommended to use the Mobil 1 filter whenever you use synthetic oil... regular filters dont have the correct filtering for synthetic oils... (correct me if im wrong)"
haha yeah no doubt ... i think the filter for my h22 was like 10.... but while we are on the fram subject... at my school we did a little project where we took a fram, and a few other filters (i think supertech was one) and cut the ends off to look at the filtering devices.... (the paper filters and whatnot) and the fram was byyyyyyy far skimping on filter agents.... there was hardly anything inside the canister... i dont wana open up a can of worms or anything, but i defiently give fram a
TonyRomo
Oct 29, 2007 01:37 PM
Lithel
10
Aug 24, 2007 11:24 AM
yujintheman
Honda Civic (2006 - 2015)
Feb 9, 2007 06:26 PM
Blazin Civic
55
Jul 11, 2004 07:01 PM
EL'ation
Apr 20, 2003 06:37 PM
