Suspension & Brakes Theory, alignment, spring rates....
On-Car Ball Joint Press, Special tool that allows ball joint swap
Old Aug 25, 2005 | 05:17 PM
LaterApex's Avatar
Default On-Car Ball Joint Press, Special tool that allows ball joint swap
I'm not talking about the ball joint tool that pops the ball joint from the lower a-arm. I've got one of those and a fine one at that. (Hond Tool Number 07MAC-SL00200).
What I seek is the tool that allows pressing of the lower ball joint out of the knuckle and then pressing of it back into the knuckle while it's still on the car.
I know that there are ball joint tools that allow you to press the ball joint out of and into the knuckle using a big vice after the knuckle has been removed but I want the one that does it while the knuckle is still installed.
Old Oct 6, 2005 | 08:07 AM
hondapwr's Avatar
Default Re: On-Car Ball Joint Press, Special tool that allows ball joint swap (LaterApex)
Hey I need one too. Any luck?
Old Oct 6, 2005 | 08:39 AM
sh!tsWEAK!'s Avatar
Haha...I need one as well..BUMP!
Old Oct 6, 2005 | 08:57 AM
Tyson's Avatar
you use the ball joint press tool available from autozone. its a glorified C clamp.
but you cannot do it while the knuckle is still in the car. the axle and axle ring is in the way. why would you want to anyway? just loosen the axle nut and upper balljoint and tie rod and calipers to remove the knuckle completely. its not that a big of a deal.
be careful about using the sleeves from the balljoint tool kit. i found them to be JUST a bit short, so that the balljoint bottoms out when almost fully pressed. it ends up crushing the balljoint tip, messing up the threads.
Old Oct 18, 2005 | 04:25 PM
CiSmoEk4's Avatar
Default Re: On-Car Ball Joint Press, Special tool that allows ball joint swap (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">you use the ball joint press tool available from autozone. its a glorified C clamp.</TD></TR></TABLE>
sorry to butt-in on someone else's thread but i just fucked up the threads on my balljoint yesterday. im really curious about the ball joint press tool that you're talking about. you say its something like a "c" clamp....so when you remove the ball joint do you just put the bottom part of the clamp on the threaded part of the joint and the top clamp on the lip of the hub where the snap ring is and tighten to push it out?? and switch it around to put it back in? thanks in advance!!!
-marcus
Old Oct 18, 2005 | 04:30 PM
Tyson's Avatar
Default Re: On-Car Ball Joint Press, Special tool that allows ball joint swap (CiSmoEk4)
i just hammered the old balljoint out.
then you use the sleeves to push the new balljoint in. it should be obvious.
just go to autozone, ask for the balljoint press.
Old Oct 19, 2005 | 02:51 PM
CiSmoEk4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i just hammered the old balljoint out.
just go to autozone, ask for the balljoint press.</TD></TR></TABLE>
u make it sound so simple. i hope it goes that well when i get mine.
Old Oct 21, 2005 | 09:33 PM
CoryTurner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">but you cannot do it while the knuckle is still in the car. the axle and axle ring is in the way. why would you want to anyway? just loosen the axle nut and upper balljoint and tie rod and calipers to remove the knuckle completely. its not that a big of a deal.
except when you make flat rate and can save urself an hour
used the honda tool and i like it lol
WhiteOnRice
Aug 18, 2024 11:11 AM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
C_Rock77
Aug 27, 2008 11:19 AM
GruvyTune
Jul 22, 2002 10:01 AM
