Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
EG rear sway bar.....any advice?
Old Aug 25, 2005 | 04:32 PM
HCivic45's Avatar
Default EG rear sway bar.....any advice?
Hi there I was wondering if there is a very good rear sway bar for the EG CIVIC in production for this car? Down here we race something similar to World Challenge, as a matter of fact the 2 realtime DC2 integras are racing agaist us.
Any sugestions?
Old Aug 25, 2005 | 04:33 PM
prkiller's Avatar
Default Re: EG rear sway bar.....any advice? (HCivic45)
Best on the market I think!
http://a-spec-racing.com/
The EG kit is now available just like the EK kits. You wont find better customer service either.
Old Aug 25, 2005 | 04:44 PM
Mike D's Avatar
Default Re: EG rear sway bar.....any advice? (prkiller)
Had a 23mm type r rear sway bar on my first hatch.
Handled well and was an easy install. If you get the hardware used it shouldnt more than 150
Old Aug 25, 2005 | 04:52 PM
civicrr's Avatar
Default Re: EG rear sway bar.....any advice? (Mike D)
Comptech 22mm rear bar/brace. You need to order the Integra model & use the 'teg lower arms.
Suspension Techniques also make a rear bar/brace combo. 7/8" (22.2mm).
Old Aug 25, 2005 | 05:19 PM
Andrie Hartanto's Avatar
Comptech, the originator, and still the best design.
Old Aug 25, 2005 | 05:21 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller &raquo;</TD></TR><TR><TD CLASS="quote">Best on the market I think!
The EG kit is now available just like the EK kits. You wont find better customer service either. </TD></TR></TABLE>
the subframe brace is simply amazing....personally i think the 32 mm hollow is too big for an eg, as it is the eg is tail happy enough with just a 22mm itr bar....
Old Aug 25, 2005 | 05:35 PM
ralphie14's Avatar
I know they make the brace but are they going to put together a kit with the ITR sway bar and all for the EG as well? All is says is pics comming soon on the site.
Old Aug 25, 2005 | 05:40 PM
chad's Avatar
Moderator
Default Re: EG rear sway bar.....any advice? (ralphie14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 &raquo;</TD></TR><TR><TD CLASS="quote">
I know they make the brace but are they going to put together a kit with the ITR sway bar and all for the EG as well? All is says is pics comming soon on the site.</TD></TR></TABLE>
yes the brace will work with itr rear bar
Old Aug 25, 2005 | 06:16 PM
prkiller's Avatar
Yep, like I said you can order the same kits as you can with the EK now!
Old Aug 25, 2005 | 06:20 PM
rambler's Avatar
New User
Default Re: EG rear sway bar.....any advice? (civicrr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrr &raquo;</TD></TR><TR><TD CLASS="quote">Comptech 22mm rear bar/brace. You need to order the Integra model & use the 'teg lower arms.
ditto!
Old Aug 25, 2005 | 06:41 PM
kaiba's Avatar
With the a-spec reinforcement kit, are you still able to run rear lower tie bar. Or does the a-spec kit act like a tie bar too?
Old Aug 25, 2005 | 06:47 PM
solo-x's Avatar
Default Re: EG rear sway bar.....any advice? (kaiba)
stock rear swaybar, run 200-300lbs more rear spring then front spring. problem solved, no additional weight.
nate - only partly serious
Old Aug 25, 2005 | 06:49 PM
prkiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">
The ASR kit is a reinforcement brace, and lower tie bar all in one. Using a lower tie bar would be worthless!
Old Aug 25, 2005 | 06:54 PM
kaiba's Avatar
The ASR kit is a reinforcement brace, and lower tie bar all in one. Using a lower tie bar would be worthless! </TD></TR></TABLE>
Just wanna know. Will be order mine soon. Bye bye OBX lower tie bar.(Piece of **** to begin with anyways.)
Old Aug 25, 2005 | 09:23 PM
Eyal 951's Avatar
Default Re: EG rear sway bar.....any advice? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">the subframe brace is simply amazing....personally i think the 32 mm hollow is too big for an eg, as it is the eg is tail happy enough with just a 22mm itr bar....</TD></TR></TABLE>
Charleston offers two sizes of hollow bars for this kit, one being smaller then the 32. Remember that these are way hollow, their setup with great engineering.
The brace is amazing, and if you want, you can use it with ITR sway, or whatever you want. that is THE setup...
Old Aug 25, 2005 | 09:38 PM
niterida's Avatar
I use the progress 24mm rear bar it works great for me
it is race only (thats what it says), but that will work for you
Old Aug 26, 2005 | 03:44 AM
.RJ's Avatar
.RJ
Default Re: EG rear sway bar.....any advice? (Eyal 951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 &raquo;</TD></TR><TR><TD CLASS="quote">
They are both 32mm OD. The only difference is the wall thickness
Its a great kit, but no engineering feat They use readily available circle track/nascar bits
Old Aug 26, 2005 | 08:11 AM
STN_Pat's Avatar
Default Re: EG rear sway bar.....any advice? (niterida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niterida &raquo;</TD></TR><TR><TD CLASS="quote">I use the progress 24mm rear bar it works great for me
it is race only (thats what it says), but that will work for you</TD></TR></TABLE>
I have the same bar and I love it. I also love the fact that it is adjustable and was cheaper than an ITR set up for me.
Old Aug 26, 2005 | 10:14 AM
Eyal 951's Avatar
Default Re: EG rear sway bar.....any advice? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">They are both 32mm OD. The only difference is the wall thickness
Its a great kit, but no engineering feat They use readily available circle track/nascar bits </TD></TR></TABLE>
I didn't mean engineering feat, i meant design is great, and fitment is awsome. Its the little things like supplying textured end nuts so you dont have to counter hold them inside the subframe that make it such great quality. Install was a pleasure. Also keeps the sway bar spaced properly to avoid binding in the sway like the beaks kit does.
Old Aug 27, 2005 | 12:42 PM
spock_rocker's Avatar
memoryFAB.com representative
im running a 19mm SRR sway/tie combo.. however im debating on whether its big enough.
philosofy1
Suspension & Brakes
Apr 17, 2005 02:09 PM
95dc2
Jan 12, 2004 11:19 AM
civicrights
Dec 7, 2003 12:40 AM
phantom_sol
Oct 14, 2003 09:13 AM
