ECU parts
Old Aug 25, 2005 | 04:07 PM
exsinnovation's Avatar
Default ECU parts
hey I was wondering if anyone knows where i can get parts to convert a p06 to have Vtec. i need these to convert it. or would any one like to trade for a p28? PLS help
* Q26: C2785 (*note: I used a C144 and it worked fine - NPN switching transistor)
* C60: 1uF 35v tantalum (marked "1 ... 35" and blue w/+ mark)
* IC14: 515 X High Side Switch
* J10: jumper wire
* R67: 820 Ohm, 1/8w 5% resistor (1k work fine says Deluded)
* RM11: weird voltage divider (this is KEY but can be replaced. Click link for more info)this could be replace by a 10k 8pin resistor module work really well
* D11: Clamping Diode
*C75,C89,C72,C74,C88: 22pF ceramic (marked "22")
*R66: 820 Ohm, 1/8w 5% resistor (1k work fine says Deluded)
(Taken from"http://www.pgmfi.org")
<U></U> <U></U>
Old Aug 25, 2005 | 05:18 PM
drdisco69's Avatar
Default Re: ECU parts (exsinnovation)
Support your local ECU hacker:
http://www.xenocron.com/produc...gkits
Old Aug 25, 2005 | 08:01 PM
Oh damn that helped a lot thanks!!!!
Old Aug 26, 2005 | 08:28 AM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
Default Re: (exsinnovation)
http://www.digikey.com
I've found pretty much everything I needed there except, surprisingly, certain multiplexers i needed, I can't find any place that sells them either. Anyone know any other good online electronics stores? DigiKey is known for being really good btw.
Modified by V8MeatHead at 9:50 AM 8/26/2005
Old Aug 26, 2005 | 03:57 PM
i like the idea of just having to buy a kit though.
Old Aug 26, 2005 | 04:30 PM
kylemarhx's Avatar
yeah, xeoncron makes it easy. just buy the kit, even comes with instructions.
digikey is good if you're buying in bulk, but they have minium orders, and inflated handling charges for small orders. for just an ecu or two, just get it from xeoncron, easier, and possibly cheaper.
Old Aug 26, 2005 | 09:58 PM
Default Re: (kylemarhx)
the uber kit is cheaper on moates.net but i cant find the conversion anywhere else...
Old Sep 6, 2005 | 08:47 AM
XENOCRON is the best!
JDM-D15B
Engine Management and Tuning
Apr 27, 2012 04:34 PM
jdmdikk
Sep 1, 2008 09:45 PM
boosted96lsteg
May 13, 2008 02:30 PM
JDM_Frijoles
Sep 18, 2006 04:15 PM
