b18a turbo....b18a tranny or b16a tranny better?
Old Aug 25, 2005 | 03:50 PM
slammedef06's Avatar
Default b18a turbo....b18a tranny or b16a tranny better?
i plan on turbocharging a 90 b18a with the stock ls cable tranny, would i benefit from a b16a cable tranny because of its quicker gearing or is that only better for all motor?
also will the ls cable tranny still fit if i swapped out the b18a block for a b20b block?
Old Aug 25, 2005 | 03:51 PM
Suck my DX's Avatar
Default Re: b18a turbo....b18a tranny or b16a tranny better? (slammedef06)
yes the ls tranny will fit on a crv block
u want the ls tranny for turbo...the shorter geared tranny will actually work against you since the shorter gears dont allow you to spool as long
GSR CAMS!!!
Old Aug 25, 2005 | 03:58 PM
Default Re: b18a turbo....b18a tranny or b16a tranny better? (Suck my DX)
good stuff! i actually have crane stage 2 cams i bought a while back, i guess i'll put those in with some aem cam gears and a new timing belt. will crane stage 2 cams for the b18a go good with the turbo or will they have too much duration or overlap?
Old Aug 25, 2005 | 04:01 PM
Suck my DX's Avatar
N/A and FI dont mix well together...
sell ur crowers and buy sum GSR ot turbo cams
Old Aug 25, 2005 | 04:03 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">yes the ls tranny will fit on a crv block
GSR CAMS!!!</TD></TR></TABLE>
gah here comes a debate.
i'll start
the only time longer gears are better are for traction and top speed. gears mutliply troque gahhh this'll go on all night won't it
or just get best of both worlds for boost GSR with LSD
Old Aug 25, 2005 | 04:10 PM
Default Re: b18a turbo....b18a tranny or b16a tranny better? (Ace$nyper)
oh i didn't know gsr cams worked in an ls head...how about integra type r cams?
Old Aug 25, 2005 | 04:22 PM
.Noah Fecks's Avatar
yeah those gsr vtec cams will work perfect with that non vtec head
Old Aug 26, 2005 | 11:07 AM
Suck my DX's Avatar
Default Re: b18a turbo....b18a tranny or b16a tranny better? (Noah *****)
my bad doggie i musta been thinkin LS/V
Old Aug 26, 2005 | 11:39 AM
Reason's Avatar
well the b16 tranny IMO is great for any application FI or N/A because but you will constantly be in high RPM's. The LS is good if you're going to be doing a whole lot of highway driving and not too much racing. but if you have the choice of the b16 or LS tranny, you might as well just get the b16 tranny
Old Aug 26, 2005 | 11:49 AM
yellowcrx1991's Avatar
Exactly what Ace$nyper said, acceleration is acceleration in a transmission, no matter the application behind it, short gears will be faster than long. If you want more info, do a search because we have run up and down this topic of turbos, short and long gears a lot.
Old Aug 27, 2005 | 10:22 AM
slow hatch's Avatar
Default Re: b18a turbo....b18a tranny or b16a tranny better? (yellowcrx1991)
But now a B16 revs to what 8000rpms while and LS redline is 6500. Now with the B16 tranny on the LS turning 6500 rpms your top speed would be like 90-100, right?? 1/4 mile speeds with any turbo LS should be over that, so I vote for the LS tranny, since you cant turn high rpms
Old Dec 29, 2005 | 09:45 PM
the.hamburglar's Avatar
Default Re: b18a turbo....b18a tranny or b16a tranny better? (slow hatch)
yeah but if you are aiming for 111mph trap speed then a nice shift into 5th and a hard pull from the turbo and shorting gearing would be good
Old Dec 29, 2005 | 10:29 PM
Malgerus's Avatar
Default Re: b18a turbo....b18a tranny or b16a tranny better? (the.hamburglar)
S1 Tranny &gt; LS. In both all motor and FI applications.
the.hamburglar
Aug 23, 2005 10:06 AM
c1v1c89h4tch
16
Mar 7, 2005 02:36 PM
soquickls
Nov 21, 2004 09:33 PM
usdm420
Apr 19, 2004 07:12 PM
Ransom
Apr 3, 2003 06:32 PM
