What are the benefits of aftermarket LCA's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adaml2nv »</TD></TR><TR><TD CLASS="quote">they look nice
he-he shiny
</TD></TR></TABLE>he-he shiny
they're about 2.5 pounds lighter. they're pretty much an OEM replacement. i didnt feel like spending 85 bucks per LCA from acura so i got omni power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectLSVTEG »</TD></TR><TR><TD CLASS="quote">you get some bling-a-ling factor</TD></TR></TABLE>
and some new bushings....
mine were shot and the price on new lcas was good...SPC
and mine are shorter than oem, so it tucks the wheels in to correct negative camber and allow wider wheels...
From: Good luck to this industry, you're gonna need it.
up for an answer...
as far as I knew, they did help correct camber...but I'd like to know for sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist »</TD></TR><TR><TD CLASS="quote">up for an answer...
as far as I knew, they did help correct camber...but I'd like to know for sure</TD></TR></TABLE>
my spc lcas DO correct camber in the rear...
on my DA, before the lca's, i had 3 washers to correct the camber,
now, there are no washers correcting camber in the rear....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hbadge4Life »</TD></TR><TR><TD CLASS="quote">so, there are no real benefits beside the bling factor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG »</TD></TR><TR><TD CLASS="quote">
new bushings....
and they tuck the wheels in to correct negative camber and allow wider wheels...</TD></TR></TABLE>
edit:^^^my SPC's are shorter than stock...some brands are, some aren't...
Modified by nickG at 7:02 PM 8/26/2005
new bushings....
not all of them tuck the wheels, function7 are the same length as stock which would not result in wheel tuck
now, there are no washers correcting camber in the rear....</TD></TR></TABLE>
By shortening the rear LCA, you also narrow the rear track. Doing this modifies rear suspension geometry and can make the car extremly unstable. This is the incorrect way to adjust camber.
Function7 LCAs are the same length as stock arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iixerOii »</TD></TR><TR><TD CLASS="quote">What are those purple LCA's that were pretty bling?</TD></TR></TABLE>
SRR
SRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR »</TD></TR><TR><TD CLASS="quote"> By shortening the rear LCA, you also narrow the rear track. Doing this modifies rear suspension geometry and can make the car extremly unstable. This is the incorrect way to adjust camber.</TD></TR></TABLE>
Aftermarket LCA's arent short enough to jepordize the integrity of the rear suspension. If the LCA were to be soo short as to actually narrow the rear track, you would have a high degree of positive camber, since the LCA is pulling the wheel in while the top hat is stationary.
I use billet aluminum aftermarket LCA's and I've ran my car hard through the local canyons here. I assure you they do not make the car "extremly unstable".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 »</TD></TR><TR><TD CLASS="quote">
While it may function, it doesn't work properly. Unless you've got numbers stating how much it does change the geometry?
