EX coupe power windows/locks into Si hatchback
As many of you know, the 5th generation Civic hatchbacks did not have power windows/locks.
My bro and I want to install the power windows/locks/wiring from a 93-94 Civic EX coupe into his 95 Si hatchback.
I'm just wondering if any one here has successfully done this project.
Also, the regulators look the same (just by looking down the door) between manual and power windows...can anyone confirm if they are different or not?
From what I gather, the hardest part is routing the wiring.
you'll need the door panels, switches, lock assembly and window regulators out of the coupe. As well as the entire wire harness for both doors and the chassis harness that has all the wiring and lock relays.
there are also two fuses you have to add to the underdash fuse box as well as the relay.
94Hatchd15b7
Apr 11, 2007 09:39 AM
97civicdx
May 31, 2003 06:43 PM
