Cable to Hydro conversion without the Kit?? I've seen it done wondering how.
Old Aug 25, 2005 | 11:50 AM
vtecn8ive's Avatar
Default Cable to Hydro conversion without the Kit?? I've seen it done wondering how.
Well I don't feel like forking over 500 bucks for a cable-hydro kit.
I want to put a b-series swap in my CRX (90) and use a hydro tranny. I know there are guys out there that say f*ck the DIYer, but I am a DIYer.
I am wondering if I use a cable b-series mount kit what problems would I run into? Is the hydro tranny different in size?
How to mount the clutch cylinder. I know I will have to cut and weld on my firewall to get this to mount that is not the problem. I am wondering how do i get the cable clutch to work with the hydro clutch? Switch pedals or is there a more in depth way to do it (fabricating my own pedal somewhat?)???
If you have any knowledge of this help me out since I help some of you guys out.
-Shane
Old Aug 25, 2005 | 11:58 AM
boost'dsiR's Avatar
Default Re: Cable to Hydro conversion without the Kit?? I've seen it done wondering how. (vtecn8ive)
my homie just left his dangling
Old Aug 25, 2005 | 01:00 PM
vtecn8ive's Avatar
Default Re: Cable to Hydro conversion without the Kit?? I've seen it done wondering how. (boost'dsiR)
not slave cylinder MASTER CYLINDER
Old Aug 25, 2005 | 01:11 PM
boost'dsiR's Avatar
he use hydralic pedals and ran the hard line to the tranny
Old Aug 25, 2005 | 02:04 PM
HogWild's Avatar
The tranny should be the same size, im not sure about mounts but i'd guess they are the same, it would be easy if you could get a whole clutch and hydraulic system from some other honda, then mount your pedal, hydraulics, run the lines then you should be in business. you may not even need a different pedal they could be the same im not sure, but the easiest way would be to get a the whole assembly from another honda. good luck
Old Aug 25, 2005 | 04:00 PM
vtecn8ive's Avatar
Default Re: Cable to Hydro conversion without the Kit?? I've seen it done wondering how. (HogWild)
oh ic I thought the trannies were different sizes and I wonder if the pedals mount the same. hmmm I gues time to purchase a set of pedals
-Shane
Old Aug 25, 2005 | 04:43 PM
Crx Jimmy's Avatar
the holes that the mount -mounts to are different if you cut, weld, drill the mount it should fit, the kit does not use a master it used some weird bracket that the cable goes into that changes the direction of the force to push the clutch fork the right way just look at a picture of one and you will see how it works its not that complicated, i was going to do the same thing
Old Aug 26, 2005 | 05:44 AM
vtecn8ive's Avatar
Default Re: Cable to Hydro conversion without the Kit?? I've seen it done wondering how. (Crx Jimmy)
I am aware how the hasport kit works. I want to use pretty much a 92+ hydro setup. master cylinder, hard lines, flex line, slave cylinder, hydro tranny.
Any more input? Anybody know if they pedals from a 92+ civic or 94-01 Integra will work?
-Shane
Old Aug 26, 2005 | 08:16 AM
Garrett's Avatar
I use a 92-93 integra cassing and installed ITR internal
Old Aug 26, 2005 | 09:59 AM
vtecn8ive's Avatar
Default Re: Cable to Hydro conversion without the Kit?? I've seen it done wondering how. (Garrett)
Yeah I was thinking about that but I want to convert to a hydraulic system. No need for cable.
-Shane
G-Auto*Hero
Aug 23, 2011 02:40 AM
dragDA
Transmission & Drivetrain
11
Mar 2, 2009 06:54 PM
ekVtecPower
Apr 16, 2006 05:53 PM
thad
Feb 10, 2004 10:27 PM
tgreaves
Nov 17, 2003 12:30 PM
