EF w/ LS Swap. What o2 sensor?
Old Aug 25, 2005 | 11:13 AM
Agent_STFU's Avatar
Banned
Default EF w/ LS Swap. What o2 sensor?
Hey everyone,
So I believe I need a new oxygen sensor. The car is a 91 Civic, with a B18B (converted to OBD0..) with a 1 wire 02 sensor. Should I order an 02 for a DA Integra LS or for my car? Will both work? Are the clips the same?
Also, where can I get an oxygen sensor from? I've done a search and all I see is 4 wires for sale.
Would I be better off just ordering I suppose, a universal o2? and just wiring it to the original sensor's wire?
Old Aug 25, 2005 | 11:14 AM
FF-Bee's Avatar
Default Re: EF w/ LS Swap. What o2 sensor? (Agent_STFU)
Since you are obd0 order it for a 90 LS motor.
Old Aug 25, 2005 | 11:17 AM
Agent_STFU's Avatar
Banned
Default Re: EF w/ LS Swap. What o2 sensor? (b_cruz)
You know of a cheap place to order online? Will the clip connect on my harness? Or will I need to wire it in?
Old Aug 25, 2005 | 11:20 AM
FF-Bee's Avatar
http://oxygensensor.net/
you can order it with or without the plug.
Old Aug 25, 2005 | 02:47 PM
Agent_STFU's Avatar
Banned
Thanks again.
I might try and see if anyone has any for sale locally before I order off the internet. Thanks B_Cruz.
Old Aug 25, 2005 | 03:11 PM
kurinto's Avatar
http://www.sparkplugs.com/ has denso o2 sensors for cheap. Get the universal one, it's the same thing you just don't get a plug on the end.
Old Aug 25, 2005 | 03:47 PM
GhettoHatch89's Avatar
Default Re: EF w/ LS Swap. What o2 sensor? (kurinto)
I think I bought mine from the local Auto Zone. They had a couple of them there for 1 wire o2's, but I think the Bosch and Denso's were the cheapest, around 20 dollars if i remember right.
Old Sep 8, 2005 | 07:10 AM
typeRclass's Avatar
Why dont you do a search on it like everyone else! And listen to you nick name and STFU!
Old Sep 8, 2005 | 07:52 AM
UsDm_Junky's Avatar
wow uneccesary roughness lets cool turn it down a notch typeR
Old Sep 8, 2005 | 08:31 AM
b18_crx's Avatar
Default Re: EF w/ LS Swap. What o2 sensor? (typeRclass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeRclass &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you do a search on it like everyone else! And listen to you nick name and STFU!</TD></TR></TABLE>
damn u have issues man...chill were here to help each other.
Old Sep 8, 2005 | 08:54 AM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_STFU &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone,
Would I be better off just ordering I suppose, a universal o2? and just wiring it to the original sensor's wire?</TD></TR></TABLE>
Yes, the universal should work fine or do as I did, unscrew the one from your HF mani and screw it into the B18. That is if it worked ok in the HF.
HTH
chris
Old Sep 8, 2005 | 10:17 AM
Agent_STFU's Avatar
Banned
Thanks n00b. Get out of my thread, e-thug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">
HTH
chris</TD></TR></TABLE>
The oxygen sensor is bad, I just need to replace it. I've already got the swap done and everything. No D-Series manifolds laying around
Old Sep 8, 2005 | 12:06 PM
PURPLETERROR aka BIGMATT's Avatar
the o2 sensor is like 17 bucks at advance auto
Old Sep 8, 2005 | 10:11 PM
Agent_STFU's Avatar
Banned
Default Re: EF w/ LS Swap. What o2 sensor? (PURPLETERROR)
Good, good. Thanks, I'll try and pick one up this weekend, I've got alot of things going on as well.
In the process of painting as we speak
hYbRid_Eg6
Aug 8, 2010 09:07 PM
efking1985
Feb 12, 2007 08:31 AM
Vtec92Civic
Oct 24, 2004 04:35 PM
CRexcellence
Jan 24, 2003 06:42 PM
EG6owner-T
Sep 7, 2002 12:39 PM
