Suspension & Brakes Theory, alignment, spring rates....
will ek rear shocks fit eg?
Old Aug 25, 2005 | 09:39 AM
rogue420's Avatar
Default will ek rear shocks fit eg?
the reason i ask is because a while ago i got some aluminum rear lower control arms for my eg hatch. the ones they sent were for an ek. the only differance i could see was where the shock mounts to the control arm and the holes for the sway bar, the bushing was alot thinner for the ek because my shocks wouldn't fit so i just put some shims inbetween the shock and the control arm and it's worked out nicely. well now that i'm changing my setup, i'm wondering if i can just use the rear shocks from an ek so i don't have to use the shims anymore? also, will i run into spring issues since spring are usually sold aas a set of 4 for specified years
Old Aug 25, 2005 | 10:11 AM
EK k kay's Avatar
Default Re: will ek rear shocks fit eg? (rogue420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rogue420 &raquo;</TD></TR><TR><TD CLASS="quote">the reason i ask is because a while ago i got some aluminum rear lower control arms for my eg hatch. the ones they sent were for an ek. the only differance i could see was where the shock mounts to the control arm and the holes for the sway bar, the bushing was alot thinner for the ek because my shocks wouldn't fit so i just put some shims inbetween the shock and the control arm and it's worked out nicely. well now that i'm changing my setup, i'm wondering if i can just use the rear shocks from an ek so i don't have to use the shims anymore? also, will i run into spring issues since spring are usually sold aas a set of 4 for specified years</TD></TR></TABLE>
Do not use the EK rear lca's on your car. They are longer than eg/dc ones.
Old Aug 25, 2005 | 10:24 AM
rogue420's Avatar
Default Re: will ek rear shocks fit eg? (chowmien)
too late, they've been on for over a year now and no wierd tire ware, tracks perfectly straight, and no visable camber issues. before i put them on i compaired them to stock and there was no visable differance in the lenth, all bolt holes matched up only differance being the shock mount bushings on the new ca were thinner.
Old Aug 25, 2005 | 10:36 AM
macDelli's Avatar
eg/ek susp. are interchangable with small modification if any
Vi3tsi06
Suspension & Brakes
28
Sep 9, 2010 10:05 PM
BrianFreels
May 4, 2009 01:36 PM
Orientalbigboi
Sep 8, 2007 11:22 AM
vizsual00
24
May 26, 2004 10:09 PM
Prevail
Sep 26, 2002 09:39 PM
